Old 01-05-2005, 11:54 PM   #1 (permalink)
mekalodu
iinfi's Avatar
Default minimise
i use microsoft outlook 2002 (10.2627.3501) SP1
is it possible to minimise it in the sys tray ??
mekalodu
iinfi is offline
Old 02-05-2005, 04:58 AM   #2 (permalink)
Web Entrepreneur
ShekharPalash's Avatar
not sure abt outlook 2003 [office xp] but u can minimize outlook in ofiice 2003 to tray...
try this application http://www.neowin.net/comments.php?i...TaskAwitcherXP
it's replacement of alt+tab function in explorer... also eats very less resource ~ 400kb ... very nice tool... after installing configure it's settings and check
"minimize windows to tray on right-click on minimize button"
done!... not only for outlook but for all progs u want to minimize
Live Chat with Doctors 24x7 on my site http://healthcaremagic.com
ShekharPalash is offline
Old 02-05-2005, 10:29 AM   #3 (permalink)
mekalodu
iinfi's Avatar
thanks man ... will try it and let you know ... cheers
mekalodu
iinfi is offline
Old 02-05-2005, 11:42 AM   #4 (permalink)
if U have Tweak-XP pro . then its very simple in tht s/w there is one option regarding minimising every window to sys-tray! so try it out .. but its only for 30 days . trial version ..
enjoy
Ankit
At times in ur life just to do things right U have to be steady & sacrifice sth which u want the most.....even ur dreamzz tooo....
yehmeriidhain is offline
