Old 01-05-2005, 10:33 PM   #1 (permalink)
Default PC PROBLEMS
My config consist of ASUS A7N8X DELUXE mobo, ATHLON XP 2400+ CPU, 512MB DDR RAM. Of late, my PC is shutting down and restarting on its own. The CPU External Frequency (MHz) is set at 133MHz and the CPU Frequency Multiple Setting is set at Auto in the Bios. Is the CPU External Frequency to be set at 100MHz to prevent overheating of the CPU, which is suspected to be the cause of the problem ? Or will a new layer of thermal paste will do the trick ?
daumaster is offline
Old 02-05-2005, 04:54 PM   #2 (permalink)
If its the case of overheating check your BIOS Hardware monitor , itll tellu about the current temperatures and check the mb manual and cpu manual for overheating temperature and match them. If its case of overheating CPU then try applying the thermal paste and see what happens and if that does not solve your problem , get your MB and Processor checked.
www.digizeal.org
Tech support + JAVA and Cisco dedicated subforums..
Come and check
anubhav_har is offline
Old 02-05-2005, 08:51 PM   #3 (permalink)
Thanks. Will apply the thermal paste tomorrow and check.
