Old 01-05-2005, 10:28 PM   #1 (permalink)
Default How to change the default installation directory.
Hi,
I have recently tried installing Bloodrayne2demo from a tech cd.
It is trying to install into my c:\ drive,but I have partitioned such a way that the root primary partition is only 3.2gb and I donot have space for it.
can any one please specify how to change the default installation directory.
I have tried searching for that in the setup_config file but found no clue.
vamsi104 is offline
Old 01-05-2005, 10:32 PM   #2 (permalink)
Before installation, the game asks you where you want to install it. The default directory probably looks something like this:
C:\Program Files\Blood Rayne Demo
To install this in some other partition, just change the C to the corresponding letter of the partition in which you wish to install.
drvarunmehta is offline
Old 02-05-2005, 01:43 AM   #3 (permalink)
Hanging, since 2004..
tarey_g's Avatar
choose custom installation instead of typical installation
Windows 8 ? :lol:
I have a better OS installed, people call it Windows7 8-)
tarey_g is offline
Old 03-05-2005, 10:21 AM   #4 (permalink)
I usually do that.
But the problem is that I am not getting a screen to choose between a custom installation(where I can choose my destination folder) and an express installation.
It is diectly switching to dexpress mode.
I think i need to mention this:
I have changed the default location of my temp directories to another drive.
should I change the home drive to some other drive also.
Please help me.
I am facing a similar problem with half-life2 also.
vamsi104 is offline
Old 04-05-2005, 10:53 AM   #5 (permalink)
Can any one please tell me if default locations can be changed in registry?
vamsi104 is offline
Old 04-05-2005, 05:26 PM   #6 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
Yessir .. See this thread ...
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
