Old 19-06-2008, 01:12 PM   #1 (permalink)
Excessive happiness
furious_gamer's Avatar
Red face Get rid off my Old-PC
Recently,I upgraded my PC from old Pentium III to a, new LGA775 P
IV
3.06GHz-HT Processor,on
a Mercury PVM7 Motherboard,512MB DDR400
RAM,80GB ATA.After installing, i
entered into dxdiag and i notice the
Display Tab.My onboard graphics was S3G
Unichrome Pro IGP with only 64MB
Memory.As a fan of GTA:Series, i think
that,64MB of video memory is not
enough to play GTA:SA smoothly, even at low
settings.I was so
disappointed. Another fact is,my motherboard doesn't have
any PCIe
slot(only one AGP8x slot).Will you please tell me,whether i can opt
for
a high-end AGP card,or a new Motherboard with PCIe slot and
onboard
graphics of atleast 256MB VRAM.
* Give me a solution for which i can
adopt.My budget for those components,
were around Rs.4K.
*Also,tell me
the difference between AGP & PCIe in short.
*Did a high-end AGP card is
enough to run Windows Vista?.(if,Suggest me such
a card)
*Will i go for e-VGA GeForce 7300GT 512MB AGP for my problem?
furious_gamer is offline
Old 19-06-2008, 10:28 PM   #2 (permalink)
Cool Buddy's Avatar
Default Re: Get rid off my Old-PC
you got an outdated system, i wouldn't have bought that 1.5 yrs ago.
Nokia 5230 :(
Canon IXUS 115 HS :)
Cool Buddy is offline
Old 20-06-2008, 01:33 AM   #3 (permalink)
Boom Boom Boom
cooldudie3's Avatar
you can always update everything, including your system but I recommend you to buy another computer, since all the hardware already have dust on them LOL
I'm back! Gimme a hugggggg... :D
cooldudie3 is offline
Old 20-06-2008, 02:25 AM   #4 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
dude, you got SERIOUSLY ripped off. You just bought a computer from 2005.
Apple iPad 2 16GB WiFi
MetalheadGautham is online now
Old 20-06-2008, 02:42 AM   #5 (permalink)
johnjjx's Avatar
Uhh u got dis sys? Recently?
Wel fr agp get a 2nd hand 66gt. Investin nymre than dis is waste.
e8400 / abit ip35-E / gskill 4gb / mx5021 + audigy 2zs / Visiontek 4870 / corsair vx450 / Dell E198wfp
johnjjx is offline
Old 20-06-2008, 04:56 PM   #6 (permalink)
Cool Buddy's Avatar
If somebody suggested that to you, then catch hold of him quickly, although that wont help.
I got a dual core PC in Nov 06 when they were fairly new and expensive. You should have sought suggestions before buying that. you can only play games 2 or 3 years old on that PC. so start saving and buy a quad core next year when they are cheap, till then, play peggle.
Nokia 5230 :(
Old 20-06-2008, 09:43 PM   #7 (permalink)
Tech Addict
IV
RAM,80GB ATA.
...........My budget for those components,
were around Rs.4K.
Look at this. He most probably got it 2nd hand.
arupch is offline
Old 24-06-2008, 02:35 PM   #8 (permalink)
Excessive happiness
Talking Re: Get rid off my Old-PC
I need your suggestions my friend not ur comments on my PC.. I bought it in 2006 November.. I was a student at that time.. So i cant fight wit my dad to get a Dual-Core or something err.. But now i gotta job.. I want to make my own complete rig and my budget for the new rig is around 22k... So i have a two choice go for a new one or get stick with f*****g old PC... If You gotta suggestion then scrap here... Anyway nice comments....
Old 25-06-2008, 12:51 PM   #9 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
comeon ppl .... not every1 is ready 2 spend 20k+ on pc`s .....
saving money is THE THING ......
i think, @rajkumar_pb ..... TRY using ur old pc 4 sometime ..... earn MONEY .... & then after somedays, re-think of budget & get the best possible thing from UR HARD EARNED money ....
... W H O T ...
ax3 is offline
Old 25-06-2008, 06:23 PM   #10 (permalink)
Excessive happiness
Thumbs up Re: Get rid off my Old-PC
Yeah ax3,
i aint try to save money... Then tell me a best configuration that which i can afford for... Money matters when it comes to earnings.. So we must have some constraint over it.. Anyhow how much you'd expect me to spend on a PC... a new Gen rig for gaming only...
Suggest me...
if i can i surely afford one..
Old 25-06-2008, 06:27 PM   #11 (permalink)
The Smaller Bang
you mean that P4 HT PC was not a PC you just bought ? Or is it THE old PC ?
If its the old PC, then keep it.
I advice the same thing as ax3.
Old 25-06-2008, 07:30 PM   #12 (permalink)
The real Bond
yogeshm.007's Avatar
Here is what I suggested to some other guy (in this thread) : -
Component;Make;Cost
CPU;Intel-E4600;5,400
Motherboard;Intel DG31PR;3,500
RAM;1GB -800;1,000
HDD;Seagate SATA 320 GB 7200;3,000
Monitor;"LG/Samsung 17""";5,500
Keyboard + Mouse;Logitec-Set-Optical-Black;750
Cabinet + PS;Any good combination;1,500
Optical Drive;ASUS LS 20x DVD Writer;1,500
UPS;600 VA;1,500
Total Cost;;23,650
With @sakumar79 suggesting:
I would suggest AMD 4600+ or 4800+ with M2A-VM motherboard instead of Intel based (will cost 1.5k to 2k less)... I think M2A-VM will offer much better on-board graphics than DG31PR... And RAM may be 2x1GB instead of 1GB (you can go for 667MHz RAM instead of 800MHz because it will not be the bottleneck IMHO)...
Thats what you can get for this budget; nowhere close to a gaming PC, though it should play most (older) games on low-medium details and 800x resolution.
GTA: SA you mentioned is very old game, you should be able to play it on full detail at 1024x res.
But I would recommend what @ax3 said
yogeshm.007 is offline
Old 29-06-2008, 11:33 AM   #13 (permalink)
ax3
ax3's Avatar
thanx ppl ...... bt do follow it ....
am using a P4 ...... & am loving it ....... have seen many ppl spending lotta MONEY on pc`s & when they sell it , u get very very less ......
ps : ooh my devil .... am i watching 2 much of Aastha, sanskar etc ....
... W H O T ...
ax3 is offline
Old 30-06-2008, 05:58 AM   #14 (permalink)
cooldip10's Avatar
I am also using a P4 and as you said it works fine.. I don't think any casual gamer needs a very high performance processor. Its the graphics card and mobo which decides the gaming factors..
Everything is Possible
cooldip10 is offline
Old 30-06-2008, 08:01 AM   #15 (permalink)
Be CoOl rAp RuLeZ !!!
krates's Avatar
arey buy a console for gaming
iPhone 3G 16GB + Samsung I450 + Sennheiser CXL 400 + PSP Phat + Samsung NC10 :D
Previous phones: N73ME , W810I , Asus P320
krates is offline
Old 01-07-2008, 04:14 PM   #16 (permalink)
Excessive happiness
I decide to buy the Intel Core 2 Duo E6300 Processor. Is it good enough to play games... And if, then suggest me a best motherboard that should cost around 5k-7k. It must support 833MHz RAM 'cause i just got a 2GB Corsair RAM from my friend as he decide to go alienware..
Suggest me
Old 02-07-2008, 01:33 PM   #17 (permalink)
The real Bond
Nice idea. But while I play NFS Most Wanted (for example) on my PC if I get caught I can escape the beating just by pressing Alt+F4. Can such tricks be applied to consoles also?
Old 02-07-2008, 02:51 PM   #18 (permalink)
Excessive happiness
I got an news that ASUS-P5-SLI costs around 6k..Is it worth to buy?
Old 02-07-2008, 04:50 PM   #19 (permalink)
The Smaller Bang
Suggest me
don't use that processor either.
Its so 2006.
If you are on serious budget, but still want to play games, and put the 2GB Crosair memory to some good use, I suggest Getting yourself a Palit N73PV motherboard with nVidia 7100 onboard graphics for 2.9K, a Pentium Dual Core E2160 for 2.7K, overclocking the CPU to around 2.8GHz, then making merry playing older games like Unreal Tournament 2004, Doom3, Far Cry, FEAR, etc without much issues at 1024x768. Keep the remaining parts with you from your former PC. This will ensure budget performance at 6K.
Old 04-07-2008, 05:57 PM   #20 (permalink)
Excessive happiness
Here is my list
Any NVIDIA SLI supported Mobo
Intel Core2Duo E6700
ASUS 8500GT
and my 2GB Corsair..
Is fair enough?
I got confused guys...
Old 22-07-2008, 01:28 PM   #21 (permalink)
Excessive happiness
The signature is showing my new PC specs.. After i got my next salary hike i think i buy a C2Q Proccy.....
My First Android phone : Samsung Galaxy SL i9003 - Rooted & Gingerbread XXKPQ
Updated : superteekz_V2 ROM for XXKPQ.
PS Request
Old 23-07-2008, 08:04 AM   #22 (permalink)
Boom Boom Boom
cooldudie3's Avatar
You really could upgrade your memory! 2GB? That's not essential for GTA!
Old 23-07-2008, 02:29 PM   #23 (permalink)
Excessive happiness
Thats cool dude....
PS Request
