Old 18-06-2008, 03:22 PM   #1 (permalink)
Default Help!! Where is my storage??
My PC shows that I have only 4.08GB left out of 70.9GB whereas when I check the total size of all the files it comes out to be 23GB...Who is using the remaining space?
I have a single partition i.e. C drive..
Also is there some tool which can show the total size of the folders as windows shows for different files when I select the "Details" option in View.
Always be OPTIMISTIC, even a stopped clock is rite twice a day....
Itz_Me!!! is offline
Old 18-06-2008, 03:30 PM   #2 (permalink)
Love Tech More than food
rahul_u_know_me's Avatar
Default Re: Where is my storage??
try using "manage" by right clicking the my computer icon on your desktop. it will give u a broder view.
Cant Live without My Computer even for a day!!
rahul_u_know_me is offline
Old 18-06-2008, 05:11 PM   #3 (permalink)
No help from "Manage" also..Its showing only 4.05GB free..
Old 18-06-2008, 07:02 PM   #4 (permalink)
gopz's Avatar
There may be some hidden files like page file etc. It might be wrongly reported due to a power failure (run disk error check or scandisk or Norton Disk Doctor for this)
gopz is offline
Old 19-06-2008, 10:10 AM   #5 (permalink)
Pagefile, hibernation file, temporary files, hotfixes backup, system restore files........ The list is very long. Use CCleaner and Windows File cleaner by using cleanmgr in run dialog box.
ThinkFree is offline
Old 19-06-2008, 12:52 PM   #6 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
use tuneup utilities 2008 ....... & clean ur pc @ 1 go ........
... W H O T ...
ax3 is offline
Old 19-06-2008, 12:53 PM   #7 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
Default Re: Help!! Where is my storage??
Use Scandisk once for any disk errors
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 19-06-2008, 12:54 PM   #8 (permalink)
There is a free software called Sequoia view which lets you visualize how much size different files and folders are taking compared to the overall space... Download and use it to get a good idea where the missing space is...
Get it at http://www.win.tue.nl/sequoiaview/
Arun
sakumar79 is offline
Old 19-06-2008, 03:59 PM   #9 (permalink)
Thank you all for your suggestions but the issue is still not resolved..
Look at the difference in actual directory size and reported directory size..
Reported size is 65.9GB
Actual size is 26.3GB..
More suggestions plz..
Old 23-06-2008, 08:03 PM   #10 (permalink)
Plz reply..
Web Virtual Storage arijitraja QnA (read only) 17 04-04-2007 06:14 PM
online storage kerthivasan QnA (read only) 17 28-02-2007 07:14 PM
Storage help ! ! ! ax3 QnA (read only) 7 21-11-2006 05:27 PM
online storage mostwanted QnA (read only) 8 07-08-2006 03:11 PM
need help about portable storage jack// ani QnA (read only) 8 07-04-2006 11:28 AM
