Old 01-05-2005, 03:32 PM   #1 (permalink)
Gracias Senor
dreams's Avatar
Default Hibernate Problem !!!
hi guys..
I hv Windows XP Pro and Intel 845 with 2.4 Ghz and 256 MB Ram..
i tried activating hibernation thru power settings but whenever i clik on enable hibernation i get a error mess like this..
" The process cannot access the file because it is being used by another process "
I hv 1 GB of HDD Space and hv used hibernation b4. Once my OS Crashed and i reinstalled Win XP Pro and frm then on i am unable to activate Hibernation.
help needed..
dreams is offline
Old 03-05-2005, 07:02 AM   #2 (permalink)
Gracias Senor
dreams's Avatar
cum on guys.. i need some help..
iPT 2G(S) - 8GB - JBn
iPhone 3GS 16GB - JBn
MAC OSx86 on P4 2.4Ghz
HTC Touch - Elfin - P3452 - WM 6.5
- Dont Dre@m... Juz Chase it -
dreams is offline
Old 03-05-2005, 10:12 AM   #3 (permalink)
Web Entrepreneur
ShekharPalash's Avatar
Same thing happened to me before few days here
I reinstalled my graphics drivers and it was woring ok.
U alos reinstall your graphics drivers.
Live Chat with Doctors 24x7 on my site http://healthcaremagic.com
ShekharPalash is offline
Old 05-05-2005, 07:47 AM   #4 (permalink)
Gracias Senor
dreams's Avatar
Will giv it a try and hope it solves my prob too..
dreams is offline
Old 06-05-2005, 07:17 AM   #5 (permalink)
Gracias Senor
dreams's Avatar
@ShekharPalash
Oops.. didnt work for me m8.. i reinstalled, updated my drivers but the same prob occurs.. need some more help guys..
dreams is offline
Old 06-05-2005, 12:40 PM   #6 (permalink)
There has to be an old hybernation file on your disk, one created by the old XP installation. Find it and delete it. This will solve your problem.
**** happens
pradeep_chauhan is offline
Old 07-05-2005, 07:27 AM   #7 (permalink)
Gracias Senor
dreams's Avatar
I dont think so m8.. i formatted my sys 2 weeks bac.. then also the same prob.. BTW can u giv me the name of the file which is 2 b deleted..
dreams is offline
Old 09-05-2005, 12:23 AM   #8 (permalink)
Biplav's Avatar
sorry 4 interruptin dreams. but i got a problem with hibernation too.
my computer takes a long time to hibernate and standby
the windows message displays"preaparing to hibernate"
4 a long time before it actually hibernates.
Biplav is offline
Old 09-05-2005, 12:37 AM   #9 (permalink)
Web Entrepreneur
in my case there was no old hybernation file 'coz before tht in tht installation i never enabled it...
@biplav... check for hyberfilsys in ur main drive it's a system file and hidden by default.... uncheck these hiding options in folder options & delete that file... & reenable hybernation.
Old 09-05-2005, 07:50 AM   #10 (permalink)
Gracias Senor
dreams's Avatar
Actually once i was using hibernation.. after i formatted my sys 3 times and those 3 times i was unable 2 enable hibernation.. the same prob.. and also tried to find the file u spec but culdnt find it.. when i uninstalled the graphics driver ther was no hibernation option.. but b4 installin it my XP automatically did the driver installation and after tht i was not able to enable hibernation.. cant guess wats wrong..
dreams is offline
Old 09-05-2005, 07:57 AM   #11 (permalink)
Web Entrepreneur
oopz.... filenem is hyberfil.sys not hyberfilsys ... it's located in the mail drive from which your system boots up usually in C:\ ...
with me when I reinstalled my Graphics Driver it was solved... don't know why it's not working in ur case... try to do one thing... Kill Explorer.exe from Task Manager and try to delete he hyberfil.sys or reinstall you grap[hics in same stage... might work... 'coz may be Explorer/some other service/application using that unused hyberfil.sys
Old 09-05-2005, 09:22 AM   #12 (permalink)
chinmay's Avatar
is it win xp home or pro?
I Blog at - http://www.chinmayspeaks.com
chinmay is offline
Old 09-05-2005, 10:40 AM   #13 (permalink)
Biplav's Avatar
its winxp pro
but i was unable to delete the file.
i copuldonly after disabling hibernation.
then again i reeabled it but the file came back too.
Biplav is offline
Old 17-05-2005, 12:37 PM   #14 (permalink)
jpushkarh's Avatar
1. I am using MP3 Flash player since from aug 04.
2. I hav restarted for no of times.
3. Then i tried to update driver but windows says that i hav newest driver. So it failed to update . . .
4. Then i disabled all 6 Generic Volumes But it also does'n work ?
How to solve prb. Hibernation is imp 4 my P !!! 500 pc else it will take time to boot . . .
Thx 4 taking intrest in my prb . . .
jpushkarh is offline
