yes there are many company to which if you send fax as email they will sent it to desired fax number.
Also you can sent fax from your telephone line with help of faxfrompc softwares.
try
http://www.maxemail.com/
http://www.freefax.com/ (totally free, site is supported by adverising)
http://www.tpc.int/sendfax.html (text messages only are free)
note i had not tested these site
