Re: AVI Chunk Viewer. Whats this ?
You installed a Codec Pack. Its nothing bad, it appears when you click on, or focus on an AVI file on your computer, and the AVI file has some problems in it. It may play perfectly, even with problems. So when the file is like that AVI chunk viewer shows the Chunk/Time graph. Its not a virus or anything. Perfectly normal.
