Old 16-06-2008, 12:16 AM   #1 (permalink)
Default Dell monitor in delhi
Hi,
I'm planning to buy a Dell 22" Monitor (Dell SP 2208 WFP). From where can I get it in delhi.
Also, if I want to buy it online, does the dell website accept debit card???
Thnx
technocool is offline
Old 16-06-2008, 07:00 AM   #2 (permalink)
cooldip10's Avatar
Default Re: Dell monitor in delhi
In Delhi you can get it from Nehru Place.. I can give you a shop's contact number if you want..
BTW where in Delhi do you live. I'm frm Vasant Kunj
Everything is Possible
cooldip10 is offline
Old 16-06-2008, 01:06 PM   #3 (permalink)
ashfame's Avatar
Even I am interested. Tell me the price you was asked for. Ok buddy.
My RIG: C2D 2.0Ghz + Intel965 Mobo + OCZ Matched Pair 2X1GB DDR2 800Mhz + LG L226WTQ 22" LCD + CM 500W PSU + Palit HD 4850 512GDDR3
HOMEPAGE : http://www.ashfame.com | BLOG : http://blog.ashfame.com
ashfame is offline
Old 16-06-2008, 10:19 PM   #4 (permalink)
I'm from Indirapuram extension. Alright buddy, can u pass the contact info of that shop please?
Old 17-06-2008, 06:34 AM   #5 (permalink)
cooldip10's Avatar
technocool
Ok then.. It'll will be there tomorrow.. I've to search for it a little.. Hope you don't mind
If your are referring to me then:
1. For 19" wide DELL with DVI input Rs 9600. With warranty.
2. Another Shop offered some other brand can't remember the name may be APEC or so..
That thing had a contrast ratio of 3000:1.. Price Rs 9200 with warranty.
dell 19 or 20 inch monitor kooki Hardware Q&A 12 12-06-2008 02:04 PM
Dell Monitor bal1961 Hardware Q&A 4 28-04-2008 03:43 AM
Best Viewsonic/Dell Monitor psmontte Hardware Q&A 1 28-02-2008 04:13 PM
- by gohan89
- by gforz
