Old 14-06-2008, 11:08 PM   #1 (permalink)
bajaj151's Avatar
Default DVD Region ?
Is it necessary to choose particular DVD Region ?...
Phenom x6 1055T 3.75 GHz | MSI 890GXM G65 | Corsair XMS3 2*4GB 1600mhz | BenQ E2200HD | Xbox 360 Controller | Seagate 2TB | CM HAF 922 | Corsair VX 550 | Logitech MX 518 | Logitech Wireless Keyboard | Sapphire 7850 OC
bajaj151 is online now
Old 14-06-2008, 11:11 PM   #2 (permalink)
TheSaint
NucleusKore's Avatar
Default Re: DVD Region ?
No, use VLC Player to play from any region WITHOUT changing the region. You are allowed to change region normally only five times.
http://www.videolan.org/vlc/
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Old 14-06-2008, 11:25 PM   #3 (permalink)
bajaj151's Avatar
But what is the purpose of defining any particular region ??
Old 15-06-2008, 09:29 AM   #4 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
To prevent piracy.
DVD-Video discs may be encoded with a region code restricting the area of the world in which they can be played. Discs without region coding are called all region or region 0 discs.
The commercial DVD player specification requires that a player to be sold in a given place not play discs encoded for a different region (region 0 discs are not restricted). The purpose of this is to allow motion picture studios to control aspects of a release, including content, release date, and, especially, price, according to the region. Many DVD players are or can be modified to be region-free, allowing playback of all discs.
http://en.wikipedia.org/wiki/DVD_region_codes
dheeraj_kumar is offline
Old 17-06-2008, 07:51 PM   #5 (permalink)
bajaj151's Avatar
How can I change region to default..?? (Vista)
Old 17-06-2008, 08:52 PM   #6 (permalink)
Thinking Different
sourav123's Avatar
You can use AnyDVD also, but it is costly.
To change your DVD region in Vista:
1. Open start menu, right click on Computer and select properties.
2. From the left hand pane, choose device manager.
3. Select your DVD drive, and right on on it and choose properties.
4. Go to the region tab, and change the DVD region and click OK.
You can change to DVD region at most 5 times in this way. After this, it will be locked in the firmware.
There is nothing more powerful than an idea whose time has come.
sourav123 is offline
Old 17-06-2008, 08:59 PM   #7 (permalink)
bajaj151's Avatar
Actually I already changed default region to region 5.....bit I forgot....the default one.
I want to know default one ...
dvd region setting neeru_igi Hardware Q&A 5 02-01-2008 01:37 AM
DVD REGION problem? evewin89 QnA (read only) 6 22-12-2007 01:27 PM
DVD region coding digit_rajesh QnA (read only) 4 14-02-2007 07:12 PM
DVD Region patkim Hardware Q&A 1 26-11-2006 11:30 PM
DVD Region Bruce_Wayne Hardware Q&A 8 22-03-2006 06:50 PM
- by gohan89
- by gforz
