Originally Posted by Varad Dilip Choudhari
I said "related" not "dependent".
Quoting Wikipedia
(Source)
the Front Side Bus (FSB) is the data transfer bus that carries information between the CPU and the northbridge of the Motherboard.
So, speaking very loosely, FSB speed is at what data travels to/from CPU and the northbridge (which usually controls AGP and memory).
Your m/board supports FSB speed of "1033/800/533MHz" means you can pair it with a processor which runs on bus spped of 1033/800/533. But your current processor supports FSB speed of 800 MHz only, so your system is running on FSB speed of 800 MHz (as you can verify from CPUz).
And now explanation why i said that "FSB Is Directly Related To Ram"
Reference from the m/board's technical reference: -
Regardless of the DIMM type used, the memory frequency will either be equal to or less than the processor system bus frequency. For example, if DDR2 667 memory is used with a 533 MHz system bus frequency processor, the memory will operate at 533 MHz.
Though in your case this does not apply, but I didn't have your full sys. conf. at the time I posted.
Regards.
