We, here in our company cant able to roll back ie 7 which is automatically pushed by domain contraoller thru windows updates. Kindly help us to install ie 6/roll back ie7.
Urgent Need.
Waiting for reply
Vijay Athreyan
Which is not working... when i restart PC. ie 7 came . and we are under Domail controlled network with auto updates enabled.... we need to install ie 6 in onely one pc. as one appilcation supports ie 6 only.
Try deleting the entire IE folder, and then following the links I gave above.
