Old 30-04-2005, 06:35 PM   #1 (permalink)
mekalodu
iinfi's Avatar
Default re writable CDs
can anyone suggest some gud quality rewritable CDs .....
everyone mite suggest sony,moser baer etc. but i wanna know with which CD one can write max. no. times.
i wud like to know how many times one can write and erase in a rewritable CD .....
chances of data loss??
what do u mean by over-burning a CD??
thanks
mekalodu
iinfi is online now
Old 30-04-2005, 06:47 PM   #2 (permalink)
Default Re: re writable CDs
There is no definite way of telling which CD one can write to the max no. of times. It all depends on how well you handle and store your CD's. But Moser Baer's will probably last longer than most brands.
In my personal experience, even after treating the CD-RW's very well, they can't be written to more than 50 times.
Overburning means adding more data to a CD than its rated capacity. You can add a couple of MB to a CD over its capacity of 700 MB. This is not recommended as some drives might not be able to read an overburnt CD.
drvarunmehta is offline
Old 30-04-2005, 07:55 PM   #3 (permalink)
why need title?
bharathbala2003's Avatar
yes varun is right.. id suggest u to try KODAK GOLD also.. its pretty gud.. but moser baer is da best as far as i know.. also there cant be any assurance that u can write it these many times.. depends on ur usage.
bharathbala2003 is offline
Old 30-04-2005, 09:14 PM   #4 (permalink)
Well, about rewritables . its all abt maintaining them .. if U can maintain them properly scratchless .. it would end up giving ya .... numerous re-writings! so I would suggest U to get neone out of the list which U must be knowing! very well ... Samsung! Moser Baer! Sony! or watever ..
Just maintain it from getting wear & tear .. & tht will do ..
Samsung! provides some high speed re-writables so U can enjoy them too! ..
gud luck!
At times in ur life just to do things right U have to be steady & sacrifice sth which u want the most.....even ur dreamzz tooo....
yehmeriidhain is offline
Old 01-05-2005, 12:20 AM   #5 (permalink)
Also a tip to make the cd last store it in a cool place (fridge is a good place.... i do it ....)
**** happens
pradeep_chauhan is offline
Old 01-05-2005, 12:52 AM   #6 (permalink)
my mosebear lasted 7 3 times
just be It was scratchless till end
8)
Happy Computing :lol:
krishnathelord is offline
Old 01-05-2005, 01:26 AM   #7 (permalink)
I got a local brand RW CD when the branded RW's were very expensive (not recomended in this post's case). It was Rs 12/-!! and another was Rs 25/-. the Rs 12 one lasted 15-16 times and the other one is still going on after 25-30 re-writes
Compaq Presario Notebook, AMD Mobile Sempron 3000+ (1.8 GHz), ATI Mobility Radeon Xpress (PCIe) 200M 128MB Graphics, 768 MB DDR 333 MHz RAM, 40 GB HDD, DVD+CDRW Combo, 15".....
krish is offline
Old 01-05-2005, 03:36 AM   #8 (permalink)
u mean full 700 mb written 50 times
or i somwtimes wrote 10 mb and then erase and then put 5 to 10 mb
so will it count or till full space is written that will be count
AMIT AGARWAL
AMITAGARWAL02 is offline
Old 01-05-2005, 12:15 PM   #9 (permalink)
Dosen't matter how much data you write. The data is always written from the inside to the outside. So even if the amount of data written is very less only the outer portion of the disc will be spared. So whether you write 10 MB or 700 MB, it won't make any difference.
Old 01-05-2005, 03:58 PM   #10 (permalink)
mekalodu
iinfi's Avatar
thanks everyone for the info ......
mekalodu
iinfi is online now
Old 02-05-2005, 03:22 PM   #11 (permalink)
vysakh's Avatar
different people have different experiences and thus differnt opinions.
To me hp is the best. Then comes moserbaer.
Incompatible message format
vysakh is offline
Old 02-05-2005, 03:34 PM   #12 (permalink)
yeah HP's CDs are good but they r difficult to find. i only find them in HP-COMPAQ showrooms or at District Centre in Janak Puri
Shwetanshu Srivastava
shwetanshu is offline
Old 02-05-2005, 04:03 PM   #13 (permalink)
club_pranay's Avatar
i have Melody CDRW (Rs40, 16 monthz back)
working perfectly
i just made sure to keep it safe, dirt free, scratch free, proper handling
Be not Thou far from me o Lord....o my strength....haste Thee to help me.
club_pranay is offline
- by gohan89
- by gforz
