How old is SATA. Did the older Intel M/Bs (intel 810,815, 845 ) contain a SATA port ?
What are the data transfer rates for conventional IDE & SATA ports respectively ?
I mean to say If I use a single hard disk of :
(i) Type- IDE, capacity X GB, at Y RPM from Z manufacturer (Without IDE RAID)
(ii) Type-SATA, capacity X GB, at Y RPM from Z manufacturer (Without SATA RAID)
then which one will give me better performance ?
