Old 30-04-2005, 07:01 AM   #1 (permalink)
Curious Guest's Avatar
Default BySoft FreeRAM 4.0.4.124
BySoft FreeRAM is a free memory management program designed for
Windows 95/98/Me/NT/2000/XP. This is done by forcing Windows to remove
all the data that is not currently needed from the memory. It can be used
manually or automatically.
***Advantages are:
· Applications load much faster
· Less blue screens
· Less lock-ups
· Allows your computer to run longer
· System cache tuning!***Features:
- Frees up RAM manually or automatically
- Easily free specified amount of RAM with shortcut
- Easily free predefined amount of RAM (5%, 10%, 20% ... 80%)
- Automatically or manually tunes system file cache
- Memory and CPU usage graph
- Uses system tray
- Skin support
- Uses system tray
Freeware
Download
http://www.bysoft.com/dl.asp?file=FreeRAM32.exe
Curious Guest is offline
Old 04-05-2005, 05:45 PM   #2 (permalink)
Distinguished Member
anandk's Avatar
i have tried it. its good.
check our RAM Idle. i found it to be better somehow !
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 05-05-2005, 01:55 AM   #3 (permalink)
been using ram idle on my old pc that has 128MB of SDRAM in it ..
system mechanic's integrated memory module is also nice...though real time freeing up of memory is not present ..
nd dont need ny ram managers for my new pc.. have loads of RAM at my disposal..(( 1GB ))
grinning_devil is offline
Old 05-05-2005, 05:54 AM   #4 (permalink)
Šupər♂ - 超人
koolbluez's Avatar
Is it better than RamIdle, FreeRamXP....
I got no probs yet...
koolbluez is offline
- by gohan89
- by gforz
