Old 30-04-2005, 01:26 AM   #1 (permalink)
Default HDD Blues NEED HELP ON URGENT BASIS.........
Respected members pls help , I have 80 gb HDD with four PArtions with two operating system. C: (98SE 10GB) , DXP PRO 10GB) , E10GB) , F45 GB) . NOW THE PAIN IS THAT I AM FULL WITH MY D: DRIVE AND JUST LEFT WITH .7 GB I AM USING WIN XP PRO AND CANT SWITCH TO 98SE BY ANY MEANS NEITHER CANT FORMAT THE DISK AND DO THE REPARTIONING DUE TO THE WORK I DO AND LACK OF TIME . PLS SUGGEST ME IS THERE ANY WAY THAT I CAN INCREASE THE HDD SPACE OF MY D: PARTION I CAN MANAGE TO FINISH ANY PARTION ON HDD PLS SUGGEST . I WOULD BE REALLY THANKFUL !!!!
dearrm is offline
Old 30-04-2005, 02:06 AM   #2 (permalink)
Get Partition Magic
http://www.powerquest.com/partitionmagic/
drvarunmehta is offline
Old 30-04-2005, 12:00 PM   #3 (permalink)
dear drvarunmehta how safe n easy is using the PARTION MAGIC
dearrm is offline
Old 30-04-2005, 12:24 PM   #4 (permalink)
There is always a chance of things going wrong while partitioning drives that have data on them. But if you had to partition, Partition Magic is the safest option. It is extremely easy to use.
Old 30-04-2005, 08:13 PM   #5 (permalink)
See that you have uninterrupted power while using Partition Magic. If there's a power failure and your UPS runs out while Partition Magic is running you'll end up with a corrupted HD which will require a reformat. End result - Lost data.
Take care,
Keith
Keith Sebastian is offline
Old 01-05-2005, 03:08 AM   #6 (permalink)
Just move your Swap file to another drive, you can move almost anything to another drive with winxp. Except the hybernate file (hiberfil.sys). I do this because in case the drive shuts down It wont spend 2 hours to reboot because some temp files were corrupted when the machine powered off. I use a partition to store the internet explorer temp files and other temp files. This way I can also back up the main windows XP drive onto another small drive adn it won thave to copy all the useless garbage with it.
AlienTech is offline
Old 01-05-2005, 02:09 PM   #7 (permalink)
Who stole my Alpaca!
FilledVoid's Avatar
If you never want to use partition Magic due oto the fear of losing something you could always sit down and uninstall those unwanted apps in xp and place them on another drive . Although not a very convienent way of doing it, the same will work .... I recall doing this to one of my systems since I didnt have access to Partition Magic then .
FilledVoid is offline
- by gohan89
- by gforz
