Old 30-04-2005, 12:31 AM   #1 (permalink)
Default problem continues
mine is the intels' 915gav motherboard not msi or any other. its intel chipset. ram is simtronics. i have put both the ram in slot 0 slot 1 and also interchanged it but the problem is still there and no i donot get any blue screens and there is no os problem. i have formatted thrice and done that. when i use the 512 ram only and remove the other0 there is no problem. it never gives me memory dump but once i put the other ram which ever it is.... i get memory dump. it just restarts and even if i disable the restart function then also it is the same. now if you have asolution then please post . it seams no one has solved this problem ????
CHETANBHALLA is offline
Old 30-04-2005, 01:15 AM   #2 (permalink)
A Year Closer To Heaven
ctrl_alt_del's Avatar
You already have a thread running on the same topic, why start a new one?
The ANGRY Pixel proudly announces the launch of India's first ever launch center for a game, The ANGRY Pixel - Milestone Interactive Street Fighter 4 Launch Center
ctrl_alt_del is offline
- by gohan89
- by gforz
