Old 29-04-2005, 09:23 PM   #1 (permalink)
jay4u's Avatar
Default Hardware Problem.....Urgent help needed ....!!!
Hi people,
I have an Pinnacle TV Tuner card. I have win SP2 installed. I installed Direct X 9b. Then i try installing Pinnacle driver. For this i used CDSpace ( an virtual image software ). The TV tuner got installed. But now both my drives Samsung CDRW and CDSpace Virtual Drive is missing. And The TV Tuner card does not start.
In device manager this is the message i am getting following message for all the 3 devices... Samsung CDRW, CDSpace Virtual CD and Pinnacle PCTV Stereo PAL Capture Device.
Windows successfully loaded the device driver for this hardware but cannot find the hardware device. (Code 41)
Click Troubleshoot to start the troubleshooter for this device.
And this one for CDRW
Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. (Code 19)
I tried uninstalling the devices and reinstalling it. also tried Troubleshooting it but in vain. Please help. I wanna use my CDRW immediately.... I cant reinstall Windows and all those stuff.
Passwords are like underwear... Change them often...
jay4u is offline
Old 29-04-2005, 09:36 PM   #2 (permalink)
Laptoping
Sourabh's Avatar
well pctv default drivers have compatibility issues with xp sp2
so i would say,
1) If you have Nero 6 Installed you need to uninstall it. It causes problems with PCTV.. Or download an updated version I believe there is a patch available..
2) Then goto ftp://ftp.pinnaclesys.de/driver/pc/pctv and download the pctvstereofix.zip file from there.
3) Extract all files to a folder and then go to Control Panel->System->Hardware->Device Manager and then select the PCTV card.. It should show that it it is not properly installed and then click to update the drivers and then tell it to search into the folder where you extracted the above files. It should install the new drivers and now your PCTV should work fine
now after the cards is up and running on the PCTV vision ( which su*ks like hell, use Chris TV the best thing tht ever happened to my PCTV STEREO) then u can sort out the probs with the optical drivers urself
post abt ur findings
Sourabh is offline
Old 29-04-2005, 10:36 PM   #3 (permalink)
jay4u's Avatar
Default Thanks
The fix file is now called PCTVStereo_WinXP_SP2_WHQL.exe and can be found in the PCTV Stereo folder
ftp://ftp.pinnaclesys.de/driver/pc/p...P_SP2_WHQL.exe
But my problem with Samsung CDRW still continues. Please help. Cant live without CDRW. Its not properly installed and says in the device manager tab...
jay4u is offline
Old 29-04-2005, 11:00 PM   #4 (permalink)
Laptoping
Sourabh's Avatar
and forgot to say this in the PM, uninstall the devices and restart windows in safe mode and c wht happens
Sourabh is offline
- by gohan89
- by gforz
