Re: CMOS settings wrong
^^ Yeah thats right, you might have either taken the jumper off(or it fell off) or you might have put it in the reset mode. Refer your motherboard manual to find the CMOS reset jumper. It can also be called an ESCD jumper, so look for that if you dont find it.
ESCD = Extended System Configuration Data
