It doesn't matter if you use "command" or "cmd". Make sure the PATH environment variable is set to C:\Windows\System32 in System Settings>Advanced>Environment Variables>System Variables. Or you can manually set the path in the command prompt by typing in:
set path=C:\Windows\System32
Playing FEAR XP/LSW2
