Old 09-06-2008, 10:29 AM   #1 (permalink)
Default Suffering From Moody Resolution
Dear Digit,
I am using Monitor : LG Flatron L1752S (17 Inch LCD) With Mine PC (845GVSR 2.4 Ghz MotherBoard With P4 Processor) Now a days I have Suffeing From Display Resolution i.e I use to Set mine Resolution 1024 X 768, Some times When I Restart Mine Pc then The Resolution Automatically Changes to 1280 X 1024. To Fix This Problem i Tries to to Change Some Settings >> Display properties >> Advanced >> Monitor >> (Here is The Problem In Monitor Section Nothing is Appering As you can see in the Pic)
So, I want to Know is their any Way to Fix that Resolution problem?? If Yes Please help
Flatron is offline
Old 09-06-2008, 11:45 AM   #2 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Default Re: Suffering From Moody Resolution
Well, I dont have a solution, but a bigger resolution is always better, isnt it? You get more work area, plus you can use your monitor to the fullest potential.
dheeraj_kumar is offline
Old 10-06-2008, 06:43 PM   #3 (permalink)
The real Bond
yogeshm.007's Avatar
Not if it is not the *native* resolution of the LCD
EDIT: Sorry, but I'm not sure if an LCD can display upper resolution than its native resolution.
Originally Posted by Flatron View Post
Dear Digit,
Try by first removing and then (re)installing the video driver.
yogeshm.007 is offline
Old 10-06-2008, 06:47 PM   #4 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Dear Digit,
LCD should be used at native resolution. For 17" it is 1280x768. Stick to this resolution. reinstall VGA card and monitor's drivers.
desiibond is offline
Old 10-06-2008, 07:11 PM   #5 (permalink)
The Devil's Advocate
iMav's Avatar
^^ 17" non-Widescreens have native of 1280x1024, his is also a non-widescreen. His monitor's native resolution is 1280x1024. Tech Specs of his monitor.
@thread starter: It is recommended that you use 1280x1024
http://beingmanan.com
iMav is offline
Old 10-06-2008, 08:20 PM   #6 (permalink)
Exactly what I was trying to say, bigger resolution is alway better You get more work area. Unless you are trying to read some long text on internet, you can lower it then.
Old 11-06-2008, 09:11 AM   #7 (permalink)
Bond, Desi Bond!
desiibond's Avatar
ah. sorry.
@iMav, thanks for pointing it out.
@Flatron, reinstall drivers and set the resolution to 1280x1024.
What is the resolution? rajat22 QnA (read only) 5 10-03-2008 11:23 AM
Hi-resolution savithk Software Q&A 1 05-02-2008 01:50 PM
LCD resolution not supported Cool Buddy Hardware Q&A 22 30-08-2007 11:44 PM
Resolution kumarn_2004 QnA (read only) 4 15-10-2006 03:37 PM
Oye! I`m suffering from VIRUS sr_ultimate Software Q&A 29 29-09-2004 01:25 AM
- by gohan89
- by gforz
