Old 08-06-2008, 05:36 AM   #1 (permalink)
s_arka_r's Avatar
Question Rapidshare Help!!!!!!!!!!!!
Guys I have a premium RapidShare Account. I schedule Flashget to d/l all the files that i select. Now, Flashget can run upto 8 multiple file d/l at once. I started all 8 and got a total d/l speed of around 230KBps. Is dat okay??? Is there any better way to extract more from RS????
- @rka $ekh@r $@rk@r
@ Kolkata
s_arka_r is offline
Old 08-06-2008, 07:56 AM   #2 (permalink)
johnjjx's Avatar
Default Re: Rapidshare Help!!!!!!!!!!!!
^mention ur connectivity speed bro.
johnjjx is offline
Old 08-06-2008, 09:41 AM   #3 (permalink)
Bot
Tiger's Avatar
if you are having BSNL home500 that is good speed thats all you can get
FoxD was here
Tiger is offline
Old 08-06-2008, 10:55 AM   #4 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Yeah thats pretty good. You can get a maximum of 256 KBPS from a Home 500 plan. (2 mbps/8 = 256 kBps)
dheeraj_kumar is offline
Old 08-06-2008, 11:58 AM   #5 (permalink)
-----ATi-----
nvidia's Avatar
Goto speedtest.net and test and check your speed..
230Kbps is good in RS.. You cant expect very high download speeds on BSNL connections.
http://twitter.com/akshayms
nvidia is offline
Old 08-06-2008, 02:10 PM   #6 (permalink)
s_arka_r's Avatar
Guys i m using Home 500 plan from BSNL....
N BSNL has installed a new copper wiring in my house (looks like a cable TV wire from outside, but has 4 pairs of copper wiring inside) And the stated speed is 2mbps to 8 mbps. So its still good u say?????
@ Kolkata
s_arka_r is offline
Old 08-06-2008, 02:18 PM   #7 (permalink)
^^ Home 500 plan is just 256kbps to 2 mbps.
Old 08-06-2008, 02:18 PM   #8 (permalink)
-----ATi-----
nvidia's Avatar
Speed in H500 plan is upto 2Mpbs. So maximum download speed will be 256KBps. So 230 isnt all that bad...
nvidia is offline
Help me with Rapidshare!!!!!!!!!!! davinci QnA (read only) 1 29-09-2007 01:33 PM
RapidShare niks999 QnA (read only) 1 31-12-2006 03:14 PM
RAPIDSHARE pranavrahul Software Q&A 1 18-03-2006 06:41 PM
rapidshare help thunderbird.117 QnA (read only) 4 15-01-2006 08:32 PM
Rapidshare godsownman QnA (read only) 6 04-01-2006 04:21 PM
- by gohan89
- by gforz
