07-06-2008, 07:56 AM
Debian Gnu/Linux User
Suggest Best Free Realtime Antispyware..
I have Avira Antivirus Personal Edition ...
it doesnt detect antispyware
Pl suggest Best free Realtime Antispyware
Living for Learning & Learning for Living
07-06-2008, 10:33 AM
Re: Suggest Best Free Realtime Antispyware..
Try Spyware Terminator
07-06-2008, 10:58 AM
spyware terminator is good.
spybot SnD also has realtime protection called teatimer, i find this less effective than ST.
07-06-2008, 11:52 AM
Legen-wait for it-dary!
Ad-Aware also has one, called Ad-Watch. Its pretty good. It never used to alert me or anything, so I thought it was a waste, then I just checked the logs on a whim, and it blocked nearly 2000 malicious stuff! that within a month!
07-06-2008, 12:07 PM
Does the free version has ad-watch?? I think the realtime protection is available only in paid.
07-06-2008, 12:15 PM
The Black Waltz
install spybot and threatfire. spybot has got a real time scanner but if u feel it isnt effective, do a full system scan once a week or so. threatfire free version does only on- demand rootkit scanning but offers real time protection against all types of malware.
#krow @ irc.freenode.net
07-06-2008, 12:51 PM
No
07-06-2008, 01:23 PM
i am using super antispyware pro but its not free.
asus psn32-e sli,1x4 ddr2 ram,nvidia stacker case,19inch lcd,sapphire hd4850 graphic card,smps 730 w from zeb
asus g73jh lappy
07-06-2008, 02:01 PM
The Smaller Bang
The best realtime anti spyware out there is the user himself.
If you are on your guard all the time, avoid using IE, and LOOK UP softwares on wikipeidia, spyware databases, etc BEFORE INSTALLING and just have a Realtime Antivirus(I recommend Avast Home), I am sure you will do fine.
Apple iPad 2 16GB WiFi
Search this Thread |
