Old 05-06-2008, 11:06 PM   #1 (permalink)
Question torrent help!! plzzzz
well i hav dwld a torrent file but only 80% is completed..., this happened in my cousins pc..., now i brought those files (da ones in downloaded folder) 2 my house n copied them 2 my pc!! so how can i download da rest of the file!!!??? can anybody plzz help???? i tried copying it in my downloaded folder but it doesn't show up in da torrent engine.... wat 2 do???? i use UTORRENT.
bhadkow is offline
Old 05-06-2008, 11:21 PM   #2 (permalink)
Davislav Ivanuiz!!!
Kl@w-24's Avatar
Default Re: torrent help!! plzzzz
This might help:
http://www.hackernotcracker.com/2007...ash-scans.html
It should work for incomplete files as well.
I was here when the forum's swear filter kept bleeping out the word 'FUNK'. :crazy::censored::eeksign:
www.abhi247.com | The Photohblog A Little Lunacy! [v3]
Flickr!
Kl@w-24 is online now
Old 05-06-2008, 11:32 PM   #3 (permalink)
its easy dude.just get the torrent file (same one which you were cousin was using)and start downloading as you would do normally.do a force recheck after it appears in utorrent window.(needless to say that download locations on ur comp must be same for both partial dwnloaded and new one)
techtricks.co.in
portforwarding
xp-vista crossover connection
installing xp on vista notebooks
sreenidhi88 is offline
Old 05-06-2008, 11:42 PM   #4 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
Well, i will try to giv a solution, but dnt knw if that will work or knw, i think it shud.. so here it goes...
SInce u hv installed µTorrent, u shud hv that same torrent file (in sum kb's) from ur cousin, now do the following:
1.) Place all the contents (that u hv 80 completed) in a folder where ever u want it..
2.) Double click on the torrent file (again on ur PC) using µTORRENT, it will ask u where to d/load files (as this is the 1st time u are using this file on ur PC).
3.) Jus navigate the torrent (for saving the files) to the folder where u earlier stored that 80% of the contents.
4.) the µTORRENT application will start checking the files (in percentages), and will continue from the 80%mark..
Try i adn reply here..
_________________
Cheers n e-peace...
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
ashu888ashu888 is offline
Old 06-06-2008, 07:52 AM   #5 (permalink)
paranj
Posts: n/a
^^that shud work. Try placing it in the same directories as others said. It worked for me. One day, I was Dwnloading Eminem discography and had to format PC so i copied the 57% files on a DVD and after formatting did as others said and continued my downloading
Old 06-06-2008, 09:00 PM   #6 (permalink)
TooR
alok4best's Avatar
I have done it so many times...not a big deal...just do what ppl have already told here.
u can do this too..start a fresh download ( just double click the .torrent file)...then stop..exit utorrent...go to the directory where it has started downloading file..now replace the existing file in this folder with the one (80%) u have...start utorrent again...done.
I wish !!
alok4best is offline
Old 06-06-2008, 10:25 PM   #7 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Yep. Done it several times too, and I think ashu888ashu888's solution is the best. You just need the torrent. But make sure you right click and force a recheck so that you can resume the download.
dheeraj_kumar is offline
Old 08-06-2008, 12:32 PM   #8 (permalink)
thanx guys but i think i mesed up somethin!!! so didn't workout for me!! anyways i ve got da whole file now...........
bhadkow is offline
Help Me Plzzzz.... a stranger Hardware Q&A 2 04-06-2008 03:43 PM
Plzzzz Help amrawtanshx QnA (read only) 4 03-02-2008 12:26 AM
upgrade help plzzzz. tehnogeek Hardware Q&A 11 26-01-2007 08:33 PM
I need a BBIIGG HELP plzzzz Abhishek Dwivedi QnA (read only) 4 21-11-2006 10:34 PM
HELP PLZZZZ!!! ashfahan QnA (read only) 4 18-03-2005 04:17 AM
- by gohan89
- by gforz
