Originally Posted by sreenidhi88
i am using xp.i will give it a try .thanks man
ive got few doubts ,please clear them(starting with 0 partitions on my 40gb drive)
1)from what i understand from your post ,ill have to create A partition in 40 gb drive (of what size) . Make a fixed page file (swap file) on the 40GB HDD in the newly created partition??of what size!!
Let the partition size be about 10-20mb greater than the swap file size.(ithe partition in the 320gb drive,where os is installed??)
finally i will be left with 3 partitions in my 40 gb drive.
1>one for page file
2>one for tmp variables
3>one for music
done with 40gb one ,now
OK, there seems to be some confusion here. Install the OS in your 320G hdd and use your 40G hdd for temp. files/swap and freq. music collection.
While there are many rules to set the swap size, the most commonly followed is hafing the swap partition of size: (1.5 * RAM) + 30MB
If you are into video editing then haf a large partition for temp. files.. mebbe 20-25GB. In this case your 40G hdd will be full and you won't be able to use it for anything else.
Hafing freq. listened-to music here is purely personal choice.
how many partitions shall i keep in 300gb drive??
i am thinking of making 5 partitions of 60gb each.wut do you say?
thanks again
my system config
512+128 mb sdram
p4 1.5ghz
digilink gigabyte intel 845 chipset mobo
450w intex smps
My suggested setup for 320G hdd is given below...
Partition number:
1) Windows + Apps which place their files in Common Files or System32 folder (e.g MS Office, Adobe, Corel etc.)
2) Programs which are independent of windows files (i.e programs which you do not need to re-install after you re-install windows)
3) Music and Movies
4) Downloads
5) Games
This way all partitions are independent of each other and if there is corruption in one partition, the data in the others are safe. I've saved a lot of time and labour with this kind of setup over the years. Plus it lets me safeguard some partitions from accidential writes/overwrites in Linux and also helps in organized sharing.
