Old 28-04-2005, 03:39 PM   #1 (permalink)
Default Dreamweaver blues
i've made a site using dreamweaver using layers to type text. I used a free host to host the site. But i adde banners and the text got misplaced . Anybody has any idea how to fix text layers at one place?? Plz hellp me. Here the site url:-
http://dbzindia.tripod.com
Your mouse has moved ... Windows needs to reboot for the changes to take effect :)
Next_Big_thing is offline
Old 28-04-2005, 06:24 PM   #2 (permalink)
NikhilVerma's Avatar
Don't use excessive layers...
Try to use as much tables as you can..
Layers cause rendering problems in some browsers...
NikhilVerma is offline
Old 28-04-2005, 07:15 PM   #3 (permalink)
man so how can I put text in it???? I also hav to add pics along but it doesn't allow text in pic line
Old 28-04-2005, 08:25 PM   #4 (permalink)
U can use the pic as background for a table and then add the text in it...
It would be better if you zip your site and post it here so I can correct it...
Old 29-04-2005, 02:39 PM   #5 (permalink)
Doesn't work!! Any else suggestion
Old 29-04-2005, 05:32 PM   #6 (permalink)
Next Big Thing,
Try not to use layers , its will just make u go crazy when tables dosent stay exactly in the same place where u wanted it.
Best is always use tables, and try to make your on template based. SO that when u make change on 1st page so that it will reflect it on the whole site.
Flip like a butterfly, sting like a bee
Butterfly is offline
Old 29-04-2005, 07:21 PM   #7 (permalink)
Man i want a suggestion to help me ... Anybody help .... I can't work how to make it out .... PLZ HELP ME!!
Old 29-04-2005, 08:42 PM   #8 (permalink)
144
144's Avatar
Dear Next_big_thing,
When you use Layers in DreamWeaver you have to understand Relative and Absolute Positioning of Layers.
When you use Absolute postioning, The layers will be positioned in relation to the Upper Left corner of the WebPage. Sometimes it will postion it to the <body> tag making this as the point of origin.
In Relative Positioning it will postion relative to another Object. For eg: relative to the bottom of a Table!
if you are mixing the 2 types? or Nesting layers with mixed types, that might be the reason for your mess-up.
On a long enough timeline, the survival rate for everyone drops to zero
144 is offline
Old 29-04-2005, 08:58 PM   #9 (permalink)
144
144's Avatar
Dear NBT,
I just had a look on the source code of ur site.
And I think , What is happening is : You haven't used any Tables. You have just inserted the Top Image "banner.jpg" and drawn 2 layers.
One for the main body and one for menu.
Now the Layers are use Absolute Positioning by default. And they consider the Top Left corner of the page as the Origin.
When you upload your site to Tripod and view on their server, they include a banner of theirs at the Top, which shifts ur Top 'banner.jpg' image down.
Although the layers are still in the same position cos they still consider the same origin of top left corner and hence they are absolutely postioned. This causes the shifting down of the top banner to overlap with the layers.
You need to include some tables into this.
144 is offline
Old 30-04-2005, 12:56 PM   #10 (permalink)
hm...Yeah I tried that thanks 4 the help
- by gohan89
- by gforz
