Old 03-06-2008, 07:13 PM   #1 (permalink)
Default Help With Zebronics Lava Cabinet
I have got a Zebronics Lava Cabinet
My problem is My front panel audio jacks. i have connected a headphone and mic set. the problem is , my mic is not workin with the front panel jack, but it works fine with the back panel. can somebody suggest me the correct pin configuration for the audio jacks(photographic description is most welcome).
My mother board is INTEL DG965RY. I am desperate to have this problem solved.
Solutions maybe sent to my e-mail id: lyamunan@gmail.com
thanks...........
lyamunan is offline
Old 03-06-2008, 07:34 PM   #2 (permalink)
The real Bond
yogeshm.007's Avatar
Default Re: Help With Zebronics Lava Cabinet
Get technical documents from here
PS: Just googled it for you
yogeshm.007 is offline
Old 03-06-2008, 08:14 PM   #3 (permalink)
dOm1naTOr's Avatar
use ur mobo manual nd see the pin config nd tril nd error method ll work.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 03-06-2008, 09:04 PM   #4 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
I have the same motherboard as you. Check the motherboard's manual (too lazy to open the cabinet...) Whatever it says on the manual works, because I fitted it myself based on that.
dheeraj_kumar is offline
Need help with Zebronics Lava Cabinet avikchaks Hardware Q&A 7 28-09-2008 05:45 PM
Mercury smps in Zebronics cabinet desiibond Hardware Q&A 4 11-10-2007 07:11 AM
Doubt with Zebronics cabinet sakumar79 Hardware Q&A 3 03-10-2007 09:36 AM
asking those who have zebronics antibiotic cabinet 56561 Hardware Q&A 8 28-04-2007 01:05 AM
Zebronics Antibiotic Cabinet Users or anyone else who can help cheen Hardware Q&A 2 16-10-2006 07:51 PM
- by gohan89
- by gforz
