Old 28-04-2005, 12:29 PM   #1 (permalink)
shreyadr's Avatar
Default how to record ?
how to record ur own voice in powerpoint presentation or flash files ?
how to create exe file from powerpoint presentation ?
SAVE MONEY - SAVE ELECTRICITY
for details e-mail me at
shreyadr@gmail.com
http://majhiduniya.wordpress.com
http://majhigallery.wordpress.com
http://majhimarathi.wordpress.com
shreyadr is offline
Old 28-04-2005, 02:11 PM   #2 (permalink)
anurag_online
Posts: n/a
To record your voice in powerpoint goto Slide Show>>record narration
Old 28-04-2005, 10:37 PM   #3 (permalink)
I am Optimus Prime
navjotjsingh's Avatar
Try http://www.google.com/search?sourcei...8&q=ppt+to+exe
You will thousands of softwares.
Always try your best before posting.
navjotjsingh is offline
Old 29-04-2005, 11:59 AM   #4 (permalink)
shreyadr's Avatar
What infrasture ot required ?
and what abt .exe from .ppt ?
shreyadr@gmail.com
shreyadr is offline
Old 29-04-2005, 11:28 PM   #5 (permalink)
I am Optimus Prime
At least search using the link given. You will find hundreds of softwares doing this. Try all methods posted before you ask for solution.
Old 29-04-2005, 11:32 PM   #6 (permalink)
anurag_online
Posts: n/a
Old 29-04-2005, 11:42 PM   #7 (permalink)
you just need a mic (Rs 20/-) to do sound recording ? I wonder what you have in mind.
**** happens
pradeep_chauhan is offline
Old 04-05-2005, 10:21 AM   #8 (permalink)
shreyadr's Avatar
HEY ! I have tried , but couldn't worked. it didn't gave any error message but my voice couldn't record or atleast i was not able to listen it. in which format it would have been saved ?
shreyadr@gmail.com
shreyadr is offline
Old 04-05-2005, 11:33 AM   #9 (permalink)
swatkat's Avatar
Try this, right click the Speaker Icon in the System Tray and click "Open Volume Controls". Here go to "Options" and select "Recording" option. Next put a check mark for "Mic" and "Line In" in the "Show the following volume controls" box. Click OK.
Next, move the volume sliders of Mic and Line In to max. and also check the "Select" option below the sliders. (If you are having "Mute" option, then uncheck it).
Then connect mic and record audio, you can use Windows Audio Recorder (only 60 seconds recording) or Audacity (a freeware) to record the audio from Line In or Mic, and save it in WAV format. Then include the WAV file in the PowerPoint presentation.
http://audacity.sourceforge.net/
http://swatrant.blogspot.com/
swatkat is offline
Old 05-05-2005, 10:48 AM   #10 (permalink)
shreyadr's Avatar
[quote="swatkat"]Try this, right click the Speaker Icon in the System Tray and click "Open Volume Controls". Here go to "Options" and select "Recording" option. Next put a check mark for "Mic" and "Line In" in the "Show the following volume controls" box. Click OK.
I did whatever u have told.
it isnot possible to select both MIc and Line in at a time
Another question is how to put any matter in the white box while repling in digit forum ? i tried many ways but don't know.
[size=9]Then connect mic and record audio, you can use Windows Audio Recorder (only 60 seconds recording) or Audacity (a freeware) to record the audio from Line In or Mic, and save it in WAV format. Then include the WAV file in the PowerPoint presentation.
ihave downloaded Audacity. i have a earphone normally u see in the advertisement of call centre staff. will that make me possible to record my voice.
i tried to record. recording starts but voice could not be recorded. are there any other settings inside the Audacity to turn on ?
btw thanx for ur suggessions
shreyadr@gmail.com
shreyadr is offline
- by gohan89
- by gforz
