Old 03-06-2008, 12:28 PM   #1 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
Default Keyboard LOCK ! ! !
any cmd 2 lock ur keyboard when ur not infront of ur pc ?? .... so that no1 messes with ur work @ office .......
cannot use logoff, many things r connected 2 my pc ......
PS: v have basic keyboards ......
... W H O T ...
ax3 is offline
Old 03-06-2008, 12:49 PM   #2 (permalink)
The Frozen Nova
casanova's Avatar
Default Re: Keyboard LOCK ! ! !
You can lock your pc.
Alternatively, just plug-out the keyboard from PC.
www.nerdweed.blogspot.com
casanova is offline
Old 03-06-2008, 12:50 PM   #3 (permalink)
What about locking computer using window key and L key combination?
ThinkFree is offline
Old 03-06-2008, 01:26 PM   #4 (permalink)
plugging out the keyboard is not a good option.you will have to restart computer to recog the keyboard again.
win key +l is a good option,setting up screen saver password is another option
techtricks.co.in
portforwarding
xp-vista crossover connection
installing xp on vista notebooks
sreenidhi88 is offline
Old 03-06-2008, 04:28 PM   #5 (permalink)
ax3
ax3's Avatar
win key +l == logoff [not advisable] ......
any other key combination ?
... W H O T ...
ax3 is offline
Old 03-06-2008, 04:40 PM   #6 (permalink)
Cool Buddy's Avatar
just put your computer to standby, and set a password for resuming. this way you will save electricity as well.
in case you are not being asked for a password when you resume, then follow these steps:
goto control panel>power options. click on advanced tab, check "prompt for password when computer resumes from standby". click OK.
Nokia 5230 :(
Canon IXUS 115 HS :)
Cool Buddy is offline
Old 03-06-2008, 04:43 PM   #7 (permalink)
ax3
ax3's Avatar
my dear @Cool Buddy ..... its an office pc not home 1 .....
just a keyboard combi will do ......
... W H O T ...
ax3 is offline
Old 03-06-2008, 04:49 PM   #8 (permalink)
Old is Gold
prem4u's Avatar
if u lock both keyboard and mouse ...then how ll u start ur work again....
u ll not able to unlock keyboard...
Is there any key..like mobile combination key to lock keypad.
and same combi key to unlock........
Even if it is there..that would be universal...so anyone crack it...
So need any specific software..then u can give ur combi key lock....
Ab kya likhe....??
prem4u is offline
Old 03-06-2008, 05:51 PM   #9 (permalink)
The real Bond
yogeshm.007's Avatar
Win_key + L will *only* lock the desktop for you. If you get a dialog box having options "Switch User" and "Log off", then simply click "Switch User". All your programs continue to run as they were.
If you are the alone person using the PC, you can also disable "Use Fast User Switching" from Control Panel -> User Accounts -> Change the way user log on or off
On a side note, I've attached an USB/bluetooth dongle to my PC. After configuration, my openSUSE/KDE combo automatically locks the PC when I (keeping my bluetooth mobile phone with me) get out of reach.
yogeshm.007 is offline
Old 03-06-2008, 06:59 PM   #10 (permalink)
Cool Buddy's Avatar
Well, that doesn't mean u wont save electricity, after all, all fo us suffer equally during a powercut
Nokia 5230 :(
Old 03-06-2008, 07:45 PM   #11 (permalink)
In my opinion you may try these options:
* Set a password in your account, press WIN+L and Switch User....in this case unless someone shutdown computer your setting are restored after login.
* Set a screensaver password and activate it before leaving computer...Best Option
* Use a thirdparty software like "Lock My PC" this is an excellent one but....... google free
paid is offline
Old 03-06-2008, 09:12 PM   #12 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
http://www.sumrasoft.net.tc/
Free software, Lock PC Now. Hav Fun
dheeraj_kumar is offline
Old 04-06-2008, 11:15 AM   #13 (permalink)
ax3
ax3's Avatar
u ppl rnt getting it ...... its an OFFICE PC ......
& its connected 2 lotta things, i just cannot LOGOFF ....
@prem4u .... many things rnt KNOWN 2 all .... this is 1 of them ......
... W H O T ...
ax3 is offline
Old 04-06-2008, 11:35 AM   #14 (permalink)
The real Bond
Please read carefully what other have already posted...
Old 04-06-2008, 02:58 PM   #15 (permalink)
Cool Buddy's Avatar
You mean that while you are not there other people should be able to access the resources through LAN or something like that, right?
then what is the problem with the screensaver option?
if it is not solving your problem then please write clearly.
Nokia 5230 :(
Old 04-06-2008, 04:28 PM   #16 (permalink)
The Frozen Nova
casanova's Avatar
ax3, if you lock your computer, your proggies would continue to run in the background. Now , when you are back just enter your password and you can start using it.
casanova is offline
Old 05-06-2008, 11:26 AM   #17 (permalink)
ax3
ax3's Avatar
again sam ans ..... u ppl dont gt it .......
@yogeshm.007 ....... u plz read carefully ......
... W H O T ...
ax3 is offline
Old 05-06-2008, 03:00 PM   #18 (permalink)
Cool Buddy's Avatar
you will just keep writing that we are not getting it or will try to make it clear? what is the problem you are facing? do you know it yourself or that too we will ahve to understand ourselves?
when evryone says you should lock the computer & u don't want to do that, then u should write clearly why you don't want to do that.
Nokia 5230 :(
Old 05-06-2008, 04:19 PM   #19 (permalink)
ax3
ax3's Avatar
@Cool Buddy .... how many times, i have stated LOCKNG up PC is not possible .....
just need a KeYBOARD LOCK ....... i knew those combi longback bt cant remember it now ......
PS : pc pros ans plz ......
... W H O T ...
ax3 is offline
Old 06-06-2008, 07:53 PM   #20 (permalink)
Cool Buddy's Avatar
then use screensaver with password, this option also, has already been suggested.
I suppose keyboard cannot be locked, see this person also didn't get any replies.
Nokia 5230 :(
Old 06-06-2008, 09:33 PM   #21 (permalink)
Tech'ing life seriously!!
sude's Avatar
try KeyboardLocker 2.5.7 (free)
from
http://www.brothersoft.com/keyboardlocker-42868.html
u can also try Chris PC LOCK (shareware).
http://www.freedownloadmanager.org/d..._Lock_19172_p/
try and comment how it had worked...
-SUDE
sude is offline
Old 06-06-2008, 09:58 PM   #22 (permalink)
Šupər♂ - 超人
koolbluez's Avatar
Cool Re: Keyboard LOCK ! ! !
from
Sude.. dude.... KeyboardLocker is shareware.
AX3... mayb this is what u r lookin for.
Here r 3 other programs. WinKeyLock, Toddler Keys & Keyboard Locker. Dont know if u can use them on ur office system though.. without admin rights
I remember a friend of mine locking his keyboard with a alphanumeric combo... but i suppose it was also based on some program running in the background. Windows by default might not b having a combo code for locking keyboards... atleast not in the recent times.
koolbluez is offline
Old 06-06-2008, 10:30 PM   #23 (permalink)
ax3,
You just want the desktop and everything to remain as it is, and only the keyboard should not be used. Right? keyboard and mouse or only keyboard? Whatever key you press on the keyboard should not work till the key combination is given. Is that what you need?
Old 08-06-2008, 01:39 PM   #24 (permalink)
jacques's Avatar
Hi
I Have A Dell Laptop Having Below Specs;
Dell Inspiron 2650
It Looks Like The Shift Buttoon Is Always On And I Am Unable To Type In Small. Even If I Press Caps The Alphabets Can Be Small However The Numbers Can Not Come At All.
Thanks
jacques is offline
Old 08-06-2008, 01:42 PM   #25 (permalink)
Press shift again a couple of times. Should work.
Old 10-06-2008, 04:06 PM   #26 (permalink)
ax3
ax3's Avatar
@koolbluez ...... u r right .... it was long back, mayb win98 ..... admin nahi bolta hai 2 install any softies ..... & screensavers r disabled 2 .....
@dheeraj_kumar .... only keyboard .... & nice signature .....
... W H O T ...
ax3 is offline
Old 16-06-2008, 07:07 AM   #27 (permalink)
Šupər♂ - 超人
koolbluez's Avatar
One more 4 u... ax3... Baby Smash
As babies smash on the keyboard, colored shapes, letters and numbers appear on the screen. Baby Smash will lock out the Windows Key, as well as Ctrl-Esc and Alt-Tab so your baby can't get out of the application. Pressing ALT-F4 will exit the application and Shift-Ctrl-Alt-O brings up the options dialog.
Old 16-06-2008, 11:30 AM   #28 (permalink)
^^ Lol, love the soft, thanks its pretty good hehe
Folder lock???? smile Software Q&A 6 15-12-2007 03:28 PM
Bios Lock!!!!! malav11 Software Q&A 6 13-11-2006 03:47 PM
How to lock one cd ? Sambit_Lucky Tutorials 1 27-08-2006 02:04 AM
IS THERE A WAY TO LOCK THE KEYBOARD?? karthik55859 QnA (read only) 2 15-04-2006 09:32 PM
Folder Lock Tom Thomas Software Q&A 7 28-10-2005 04:45 PM
- by gforz
- by gohan89
