Old 03-06-2008, 11:59 AM   #1 (permalink)
Exclamation using computer without hard disk!!
hi guys i want 2 use my computer without hard disk..., is it possible to do that???
i have some linux live cds and a 2gb pendrive. so can i use these 2 to run a system??? can anyone plz tell me how..??? n will it b possible to configure it so that i can use my bsnl broadband connection on it???? can somebody plz tell me how 2 do this all.....,the drivers required etc etc......
is this really possible??? suggest anyother methods as well but i donot want 2 use my hard disk but b able 2 browse the net.....
i want da system for only 'browsing'!!
bhadkow is offline
Old 04-06-2008, 12:34 PM   #2 (permalink)
Default Re: using computer without hard disk!!
Yes, this is completely possible. In fact, I keep a bootable USB of SLAX(www.slax.org) with backups of important files with me just in case of a hard drive failure. Go to that website, and download the tar file. Extract the contents to a pendrive and if you're on windows, open command prompt and go to the drive letter of the USB, change directory into "boot" and run bootinst.bat (this process can be done by double clicking on the .bat on windows, I think), or if you're on Linux, open terminal and go to the place where the USB is mounted, cd into "boot" and run the file bootinst.sh as root ("sudo sh bootinst.sh" if you're running Ubuntu)
I don't have a BSNL connection, so I'm not sure about this, but they should have an external router capable of dialing into BSNL. If you set it up so that the router dials into the internet connection instead of having to dial through the computer, then you just need to connect the router to the computer through ethernet (LAN port) and then turn them both (router and PC) on.
Sukarn is offline
Old 04-06-2008, 01:02 PM   #3 (permalink)
The real Bond
yogeshm.007's Avatar
Refer to
http://en.wikipedia.org/wiki/Live_USB
http://www.pendrivelinux.com/
http://en.opensuse.org/Installing_Su...rnal_USB_Drive
I also wanted something like this, though only for emergencies, not for general use. I had then visited a web-site giving more exhaustive information on the subject, but unfortunately I did not bookmarked it (trusting my google skills) and am now unable to locate it Apart from other things, it said installing on a regular usb flash drive is not recommended generally because of limited number of write cycles supported by them.
yogeshm.007 is offline
Old 04-06-2008, 03:33 PM   #4 (permalink)
thnx guys well actually wen i remove my hd n go out of town my dad complains bout not able 2 use sys for net!!! so i wanted da solution badly!!! thnx again guys.....
wil try my luck
anymore detailed suggestions fellow digitians???
bhadkow is offline
Old 05-06-2008, 05:28 PM   #5 (permalink)
i hack.. sometimes
johny rico's Avatar
Use Knoppix cd. don't use live DVD's, it'll run very slowly.But you cannot install any new software or patches without HD
May the Force be with you
johny rico is offline
Old 05-06-2008, 11:02 PM   #6 (permalink)
k...thanx ...., jus wanted 2 browse net!! dats it..... with cds runnin n net can i save files 2 usb pendrive???
bhadkow is offline
Old 06-06-2008, 11:26 AM   #7 (permalink)
Thumbs up Re: using computer without hard disk!!
Yes you can
ThinkFree is offline
Hard thinking about Hard Disk power_8383 QnA (read only) 10 25-03-2008 05:14 PM
all files from IDE hard disk with windows 2000 to SATA II hard disk with windows jagadish2005 Software Q&A 8 10-04-2007 11:08 AM
compaq deskpro ep/sb series not detecting hard disk disk aditya169 QnA (read only) 3 22-05-2005 07:14 PM
Using OS on a old hard disk on a new computer. Help please. Scorpio QnA (read only) 6 17-05-2005 10:56 AM
80GB hard disk converted into 10780 MB hard disk ssingha QnA (read only) 12 24-08-2004 11:57 AM
- by gforz
- by gohan89
