Hi every1
recently I read about T++, an accounting software which boasts abt being equal to tally7.2 in almost every function.
However I downloaded the setup file from their site(Any1 intrested, Plz Reply).
After the download when i run the setup, it says it needs a .NET Framework (version 1.47 or higher) and advices to obtain from microsoft's site, which i did( version 2.0) but after running that setup, when i run the T++ setup again, it says the same error.
its the second time i had dowlaoded a product from the Microsofts website n it seems not to b working earlier it was DirectX9.0c(which was replied by none of the geniuses of this forum).
BTW sys specs r
OS WinXP/with SP2 Integrated
P4 2.8 Ghz HT
Intel 915 Mobo
512 Mbs DDR
Hoping for a good answer this time.
Any screen shot or diagnostic detail needed will b supplied
OLD PROBLEM(Still Unanswered)
I got a directX problem please reply if u can help
I got
p4 2.8 gh HT
intel915 motherboard
512 MB ram
200gb SATA
80gb PATA
My OS is WinXp with services pack 2 integrated
i got all my drivers n other things in place
PROBLEM
i got direct X 9.0b installed
i downloaded directX9.0c from microsoft
but after installing it i was not able to run the programs for which i needed the dX9.0c
So i diagnosed it and in dxdiag command ifound the diectx file qasf.dll was having some problem.
i even tried searching the qasf.dll and replacing it with the latest downloaded version of the same file.
I had updated my drivers for graphics as well.
THANKING U IN ADVANCE
JOHNY
