Old 28-04-2005, 01:41 AM   #1 (permalink)
Default audio codec
hi,
i dl a ripped version of an English DVD movie. its Xvid codec. But the volume is very low thou i have the max sound. i installed the ACE mega codec pack for selecting the filters and audio decoders.. but it contains hell lots of stuffs that i am confused. pls suggest me the best configuration for both audio and video. thanks.
/legolas
PS: any1 if known more abt ACE pack pls help me with how 2 go abt it also!
legolas is offline
Old 28-04-2005, 03:46 AM   #2 (permalink)
In my personal experience, DVDs usually have low volumes. That may be a reason for the low volume. Try all the available audio options to pump up the volume, i.e., the media player, main windows volume control, etc.
Nemesis is offline
Old 28-04-2005, 12:11 PM   #3 (permalink)
yes. i managed 2 download the ACE mega codec pack and use the AC3 filter that comes with it and modified the o/p to +20 dB gain.. and the audio is much higher than essential! thanks...
/legolas
legolas is offline
Old 29-04-2005, 06:44 PM   #4 (permalink)
parthbarot's Avatar
ys its AC3 filter....which is for AC3 Audio for ur ripped XVID avi.....
i m using that...u r right.
it gives problem .. after some time,volume slows down.....
i tried to see film in WMplayer 8,9,10...Audio is grt..not going slow...try MEDIA PLAYER..ok?
regards
www.techlads.com
Paarth.
parthbarot is offline
Old 29-04-2005, 08:18 PM   #5 (permalink)
or! else try VLC media player tht too is a great player ..
I think U will easily notice the volume difference with ne other player!!
At times in ur life just to do things right U have to be steady & sacrifice sth which u want the most.....even ur dreamzz tooo....
yehmeriidhain is offline
- by gforz
- by gohan89
