hi friends i have lot of dvd movies in my system i thought to dump it in dvd's but it will take so many dvd's to write it...
please help me out.. is it any software s der for reducing the size of the video file....
You can reduce the size of the video only if you reduce the quality. Try DVD Shrink.
^^ compressing and extracting take TOO much time. Tried already.
Winzip and Winrar are primarily archiving tools...they wont compress an already compressed movie file. for a full dvd they will hardly reduce fee MBs..
the only feasible way is to rip the DVDs in .avi or .mp4 or similar formats which itself would take reasonable time and a decent processing power
you can use total video converter to change the format of you DVD videos into any of the available formats.... and according to the size and quality you require..!!!
and then write the compressed videos on dvd's i think the no. of dvd's you require would reduce a lot....
