Old 28-04-2005, 12:24 AM   #1 (permalink)
Curious Guest's Avatar
Default ZoneAlarm Security Suite
5.5.094.000 is out
ZoneAlarm Security Suite is the easy-to-use, comprehensive security solution
that is based on the world's best firewall to keep out hackers, viruses, worms,
and other threats. It combines the most popular firewall with antivirus, Web site
filtering, privacy protection, instant messaging security and more to provide
the best overall protection of any PC security suite.
ZoneAlarm® Security Suite - Complete Internet Security:
* Firewall - stops hackers from getting into your PC
* Antivirus - blocks and removes viruses
* ID & Privacy Protection - safeguards privacy & protects data
* Email Security - prevents email worms from spamming your address book
* IM Protection - secures instant messaging conversations
* Spam and Anti-Phishing Protection - blocks spam emails and phishing
scams
Along with its effective and easy-to-use firewall protection, ZoneAlarm
Security Suite adds privacy, security, and virus-protection features.
ZoneAlarm's wizard makes configuring a firewall incredibly easy. The app's
stylish interface and simple slider controls make maintaining and updating
settings a snap. Experts will appreciate options that let them set up custom
rules. The program's Zones feature also allows you to assign different
security levels for local networks and the Internet. We found ZoneAlarm
Security Suite to be very good at recognizing and automatically including
settings for our local network. In all our tests, the firewall guarded against all
external and internal threats it encountered. Beyond the firewall function,
ZoneAlarm Security Suite includes an antivirus scanner based on Computer
Associates' Vet Anti-Virus. The cookie cleaner and ad blocker were effective,
but the pop-up stopper failed a number of tests. The privacy-protection
features let you apply settings individually to different Web sites. The ID Lock
feature stores personal information, such as social security and credit card
numbers. Security Suite is the only version of ZoneAlarm to incorporate a
basic filter that blocks sites according to various types of content; you can
configure it to block various types of naughtiness or just one category, such
as racist material. Security Suite also incorporates the company's IMSecurity
program, which protects instant-messenging programs from spam and
encrypts messages (so long as the person on the other end also is using
IMSecurity). Users looking for one solution to just about all their Internet
security concerns can turn to ZoneAlarm Security Suite.
System Requirements:
-Windows 98SE/ME/2000 Pro/XP,
-233 MHz Pentium or higher,
-20MB of available hard disk space, Internet access.
-Minimum system RAM: 48MB (98SE/ME), 64MB (2000 Pro), 128MB (XP).
-Supported protocols for email scanning: POP3 and IMAP4 for incoming;
SMTP for outgoing; IMAP4 is not supported for antivirus email scanning.
Homepage
http://www.zonelabs.com
Curious Guest is offline
Old 28-04-2005, 08:47 AM   #2 (permalink)
Pls continue here http://www.thinkdigit.com/forum/viewtopic.php?t=19352
Shwetanshu Srivastava
shwetanshu is offline
- by gforz
- by gohan89
