any idea which allows two computers to share data and access each other...plz tell only softwares names n dont offer advice on connecting wid them wires
To follow the path:
look to the master,
follow the master,
walk with the master,
see through the master,
become the master. -Zen
if i am not wrong, you won't need any software to accomplish that. a regular wifi connection with shared folders will do the trick. Just add Wifi cards to each of your computers, set them into a private network configuration using the ad-hoc method. After that share the folders that you want to access from other computers from their properties.
exactly how do u want the data to be shared?
a red only or full share? And what type of network u wish to implement?
a private n/w through internet? or a LAN or a wifi network?
plz be specific for better help
i want all computer data to b shared without buying anything..via internet not lan as dose 2 computers are quite away from each other n it will nigh impossible to do da job
To follow the path:
look to the master,
follow the master,
