Old 31-05-2008, 09:04 PM   #1 (permalink)
The Revolutionary
thetillian's Avatar
Smile DVD Ripper suggestion
I wanted to convert many dvd's that i had to xvid format, please suggest me a good dvd ripper shareware or freeware with following requirements
1. Can convert selected titles if can chapters.
2. Want to configure the codec configuration options manually.
3. Can convert some what fastly.
And donot say ImToo, because i had it and it is not good
Thanks in advance for the help.
"It Is Not The Position You Stand, But The Direction In Which You Look."
thetillian is offline
Old 01-06-2008, 01:59 AM   #2 (permalink)
Default Re: DVD Ripper suggestion
Try Handbrake.
Our deepest fear is not that we are inadequate Our deepest fear is that we are powerful beyond measure
karmanya is offline
Old 01-06-2008, 02:52 AM   #3 (permalink)
Seed is the Life!!
shift's Avatar
try AutoGK
Stupidity Causes Cancer !!
shift is offline
Old 01-06-2008, 07:21 AM   #4 (permalink)
The High 5 Flyer
sam9s's Avatar
For ripper nothing beats DVD Decrypter or DVD FAB platinum, ripping is just one of the 100s tasks these appications can do. For conversion best application out there is VitrualDUB MOD. Though its kinda difficult to comprehend the options Vdub offers but it definately gives one of the best reasults out there. Refer some guide available online. I have used star Divx converter as well and was pretty happy with the result.
sam9s is offline
Old 01-06-2008, 08:23 AM   #5 (permalink)
Attitude matters
Ponmayilal's Avatar
Eversince I stumbled on this tutorial http://www.thinkdigit.com/forum/showthread.php?t=32980&highlight=copy+DVDs
by go4saket, I have been using Ripit4me for ripping DVDs.
I have also been using the licensed version of DVDFab Platinum.I think that the free trial version has some limitations. You may not perhaps be able to select individual chapters etc. So check on it before downloading.
For conversion, amongst the many options you may also try Mediacoder.Nothing like trying out the various options and finding the best one which suits you.Each one may have his own favorite.
Ponmayilal is offline
the best dvd ripper of all! upendra_gp QnA (read only) 5 07-05-2008 02:51 PM
best dvd ripper vijaythefool QnA (read only) 6 10-04-2008 10:24 AM
cd to pcm ripper vicky_l7 QnA (read only) 1 06-09-2007 10:28 PM
DVD Ripper RazrBlade QnA (read only) 1 10-01-2007 12:07 AM
Best DVD ripper Heavyboy QnA (read only) 6 14-12-2005 12:46 PM
- by gforz
- by gohan89
