Old 31-05-2008, 08:45 PM   #1 (permalink)
nix
Senior Member
nix's Avatar
Default DVD R contents disappeared... :(
hi, i m new to the world of dvd burning. the other day i burned a dvd about 50 % full with my favorite tracks. after burning , i re-inserted the dvd to check contents, they were there, so i deleted the backup. a few days later (now), the same dvd shows up as a blank I.e. its empty, it says 0 items. but on the back side of the dvd, i can see the signs of a successful burn (ie the track kinda mark is visible).
what do i do now? did i make a mistake somehwere...
nikhilspoliticalblog.wordpress.com- Common man bows to amitabh
nix is offline
Old 31-05-2008, 09:17 PM   #2 (permalink)
Default Re: DVD R contents disappeared... :(
same thing happened to also. the only difference was i bought the dvd from a grey market. it was a tamil movies dvd
temperworld is offline
Old 31-05-2008, 09:21 PM   #3 (permalink)
Davislav Ivanuiz!!!
Kl@w-24's Avatar
U can try to recover the contents using IsoBuster.
http://www.isobuster.com/isobusterdownload.php
I was here when the forum's swear filter kept bleeping out the word 'FUNK'. :crazy::censored::eeksign:
www.abhi247.com | The Photohblog A Little Lunacy! [v3]
Flickr!
Kl@w-24 is online now
Old 31-05-2008, 09:23 PM   #4 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Your drive may be faulty. If the dvd works in another comp, replace your drive. If not, then the DVD might be faulty.
dheeraj_kumar is offline
resolution disappeared bhaskar 789 Hardware Q&A 4 03-10-2007 12:23 AM
Fog has disappeared and there is light now drsethi Random News 6 06-11-2006 12:34 PM
Log In User Name/Icon disappeared Aijaz Akhtar QnA (read only) 3 09-11-2005 11:08 PM
LAN Disappeared !!! mohit Networking 1 04-06-2005 04:07 PM
LAN card disappeared Ricky Networking 7 19-04-2005 08:06 PM
- by gforz
- by gohan89
