Internet explorer is conflicting with some other programs memory space. So check what you installed before getting this error. Uninstall those programs one by one and check if you get the error or not. You'll then come to know what is the problem.
www.digizeal.org
Tech support + JAVA and Cisco dedicated subforums..
Come and check
