LinkBack (1) Thread Tools Search this Thread Display Modes
Old 31-05-2008, 11:47 AM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
666
solomon_paulraj's Avatar
Default TATA Sky to PC!
can i record tata sky channel programs on my pc using tv tuner card?
any one done it?
MSI-P35-NEO| C2D-E7300 | XV-9600GT | WD-640 | LEADTEK-DTV-1800H | CORSAIR-TWIN2X2048-6400C4DHX | ZEBRONICS-PRO M500W | SONY-DRU-V200S | LOGITECH-X90 CORDLESS
solomon_paulraj is offline
Old 31-05-2008, 11:54 AM   #2 (permalink)
Default Re: TATA Sky to PC!
You can't do this by just recording using tv tuner card as the signals are encrypted. Don't know if possible using any software
ThinkFree is offline
Old 31-05-2008, 12:06 PM   #3 (permalink)
Web developer
narangz's Avatar
you can do it by connecting the output from STB to TV tuner's AV in, AFAIK>
narangz is offline
Old 31-05-2008, 12:11 PM   #4 (permalink)
It won't work
Old 31-05-2008, 12:19 PM   #5 (permalink)
Web developer
narangz's Avatar
arey the output it gives is same for tv or tv tuner card. i think it should work.
narangz is offline
Old 31-05-2008, 12:32 PM   #6 (permalink)
ex3n1us m4x1mus
preshit.net's Avatar
It does work. I do it some times.
Uzgimaga
preshit.net is offline
Old 31-05-2008, 06:14 PM   #7 (permalink)
Davislav Ivanuiz!!!
Kl@w-24's Avatar
It works. U'll just need to connect using the video out and the left/right channels from the STB to the tv tuner card and set the video source as 'composite' in ur tv tuner software.
I was here when the forum's swear filter kept bleeping out the word 'FUNK'. :crazy::censored::eeksign:
www.abhi247.com | The Photohblog A Little Lunacy! [v3]
Flickr!
Kl@w-24 is online now
Old 06-06-2008, 09:25 PM   #8 (permalink)
you can simply capture channels using tv tunner card by connecting av code or by rf code.only one channel at a time.
Carnage13 is offline
Old 17-06-2008, 07:58 PM   #9 (permalink)
Can anyone confirm that they have done recording with tatasky, does it work, does it record stereo sound.
I want to buy tuner card to record music shows.
ranjan2001 is offline
Old 17-06-2008, 08:07 PM   #10 (permalink)
I have recorded numerous episodes of Friends using my Pinnacle Tv tuner and my TataSky connection. You just connect the STB to the tuner using the regular cable instead of the composite cable. Tune the tuner to channel 68 and record! Whats the big deal?
paraman is offline
Old 17-06-2008, 08:14 PM   #11 (permalink)
Thanks for the confirmation, is it the external box or the internal card, does it record stereo sound left /right channel?
Old 17-06-2008, 08:16 PM   #12 (permalink)
99.9% Idle
axxo's Avatar
yes you can capture live tv shows from tatasky. I have recorded many shows and still doing it. All you require is an analog TV tuner card..even a cheap intex card will do the job. Stereo sound? not sure. you may get a mixed output of left and right channel because of single line in socket.
axxo is offline
Old 17-06-2008, 08:23 PM   #13 (permalink)
left this forum longback
praka123's Avatar
I have tried a pinnacle pctv 50i analog tuner with SUN DTH and Linux. you have to get a S-video cable and connect between STB and tuner card.get the left and right audio o/p from STB and give it to the tuner/onboard audio line-in .you may need a cable with single pinn in order to plug into onboard or tuner audio input.
next fire up the software which you use to record.select S-video i/p and line-in audio.thats it!.
PS: I dont know whether dishtv or tata sky got s-video and stereo audio o/p for SUN DTH only!
praka123 is offline
Old 17-06-2008, 08:33 PM   #14 (permalink)
99.9% Idle
axxo's Avatar
^ tatasky has got s-video and stereo audio out thats for sure
axxo is offline
Old 17-06-2008, 08:38 PM   #15 (permalink)
thanks for confirming this, I assume u have recorded it as stereo..........right??
or its based on ur information from some source.
Old 17-06-2008, 08:41 PM   #16 (permalink)
a_g = JPKN
s18000rpm's Avatar
NO s-video in tata sky set top box.
ASUS K53SV SX520D + BF3
s18000rpm is online now
Old 17-06-2008, 08:42 PM   #17 (permalink)
I want good quality recording as I am sound critical person same goes for video , do these card stretch the normal TV 4:3 ratio to fit or keep it as it is. My lcd 20 inch runs at 1680x1050 & last time I demoed 2 cards the guys could not stop the image from stretching.
How about CPU usage, since these are all software based recording, does it go too high?
Old 17-06-2008, 08:44 PM   #18 (permalink)
99.9% Idle
axxo's Avatar
I'm using a custom audio cable, a 2 pin out to 1 pin in cable for audio. If you use the audio cable that comes with tatasky you will be getting mono audio.
No source personal exp..
axxo is offline
Old 17-06-2008, 08:44 PM   #19 (permalink)
WHAT?????
whom do I believe now? I hope they have the same STB across the country or do they have separate models with S-video?
Old 17-06-2008, 08:46 PM   #20 (permalink)
99.9% Idle
axxo's Avatar
am not sure what s18000rpm referring to...anyway i will better attach a scnshot later
edit:
..may be am wrong..is that composite video out???
axxo is offline
Old 17-06-2008, 08:46 PM   #21 (permalink)
a_g = JPKN
s18000rpm's Avatar
Originally Posted by ranjan2001 View Post
WHAT?????
in my STB , theres' no s-video.
Old 17-06-2008, 08:49 PM   #22 (permalink)
I am thinking of buying this
http://www.leadtek.com.tw/eng/tv_tun...&pronameid=399
I am not sure if its available in Delhi or not but it has most features which I need & its vista compilable but i still need x64 driver to work else its no use to me.
edit:
Whats the difference between 2 of them??
Old 17-06-2008, 08:52 PM   #23 (permalink)
99.9% Idle
axxo's Avatar
I use compro video mate card..while doing mpeg-2 recording i notice 50-60% cpu usage..also have setting in compro software to set the display mode 16:9...although am on crt.
axxo is offline
Old 17-06-2008, 08:57 PM   #24 (permalink)
a_g = JPKN
s18000rpm's Avatar
see, no s-video
Old 17-06-2008, 08:57 PM   #25 (permalink)
99.9% Idle
axxo's Avatar
composite out/in is yellow in color, s-video in black (again not sure)
qualitywise i still have no idea to what extent the difference will be.
actually my software assumes composite as s-video so as this confusion
see, no s-video
so quick huh...sorry its composite then.my correction.
axxo is offline
Old 17-06-2008, 08:59 PM   #26 (permalink)
50-60% is quite high, what about the hdd activity, does that light up as long as its recording or does it have some kind of buffer space. The system wuld generate lot of heat though I have a good airflow cabinet, but just want to be sure before I go this route.
I have a good spec of my system & over that I would be on x64 bit OS that might help to reduce CPU effectively provided the driver /software supports x64bit.
Life is becoming too busy & I miss my programs badly.
see, no s-video
I love this forum, your quick replies make me addictive of this forum.
Thanks for posting the images.
Old 17-06-2008, 09:06 PM   #27 (permalink)
99.9% Idle
axxo's Avatar
hdd activity is not much but noticable if you have hard look into it...afterall mpeg02 consumes 30mb per minute(approx)
cpu usage also depends upon the encoder you use, mpeg2 or divx or any other..
axxo is offline
Old 17-06-2008, 09:09 PM   #28 (permalink)
In that case I should look for divX capable card so it eats up less space on hdd & less cpu.
Old 17-06-2008, 09:12 PM   #29 (permalink)
99.9% Idle
axxo's Avatar
divx encoding is best if you not gonna edit afterwards,i.e once the capture process gets done. I meant if you want to edit and process the captured video(for removing ads, add your own logos,etc) then mpeg-2 would be the better option.
axxo is offline
Old 17-06-2008, 09:19 PM   #30 (permalink)
Oh is that the case?
Cant we edit divX, is there too much loss of quality?
I surely would edit those programs which I want to keep achieved.
IN my case at leasat 70-80% of programs will be edited rest will be just seen once & discarded.
2 good threads which I have been reading on TV tuner card, hope other members may need this info too.
pls suggest a TV TUNER CARD for recording
another one
Buying Guide : TV Tuner for TFTs Wide Screen [19 or 20"]
LinkBack to this Thread: http://www.thinkdigit.com/forum/qna-read-only/89277-tata-sky-pc.html
Digital Video Recorders - Omanforum This thread Refback 07-02-2011 06:27 PM
Tata Sky Or Dish Tv ? gauravgogiakavi QnA (read only) 17 09-02-2009 06:24 PM
Say Tata for WIMAX!!! dreamcatcher Technology News 3 08-03-2008 04:02 PM
Dish TV or Tata Sky? amitskale QnA (read only) 15 19-10-2007 11:51 AM
Tata Motors launches Tata Indigo LS <A entry level Sedan> Kiran.dks Random News 9 19-05-2007 10:37 AM
Dish TV vs TAta sky which is best ???? dinesh_mettur QnA (read only) 27 09-04-2007 02:28 AM
- by gforz
- by gohan89
