Old 31-05-2008, 10:13 AM   #1 (permalink)
Ashok Verma's Avatar
Default will 1GB RAM works fine with 512MB?
well friends,
i'm planning to increase my system's RAM and thinking to buy 1GB RAM.
for my PC. Someone told me that you will can't use both RAMs together.
please tell me is this thing true.
my system configuration is:
windows XP SP2
Intel P4 Processor, D865GSA Intel Motherboard
512MB RAM,
80 GB seagate HDD
Sony DVD-RW
Ashok Verma is offline
Old 31-05-2008, 11:02 AM   #2 (permalink)
NP : Crysis
xbonez's Avatar
Default Re: will 1GB RAM works fine with 512MB?
if frequencies of RAM match, u can use any two capacities together
xbonez is offline
Old 31-05-2008, 11:22 AM   #3 (permalink)
Bond, Desi Bond!
desiibond's Avatar
yes. It will work. just make sure it has same Frequency and same timing. Much better if it comes from same manufacturer.
desiibond is offline
Old 31-05-2008, 11:10 PM   #4 (permalink)
TechTin.com
ravi_9793's Avatar
Originally Posted by Ashok Verma View Post
well friends,
windows XP SP2
512MB RAM,
80 GB seagate HDD
Sony DVD-RW
yes will work.
Make sure your motherboard support 1.5 GB of memory. Read the MOB manual.
ravi_9793 is offline
Old 01-06-2008, 07:53 AM   #5 (permalink)
The High 5 Flyer
sam9s's Avatar
to add to what people already said, even if the frequencies do not match, the ram would still work but on a lower frequency of the two modules. Say for eg you have a ram at 400mhz and other one at 200mhz the 400 one would work on 200 if coupled with the 200 one.
sam9s is offline
Old 01-06-2008, 11:37 PM   #6 (permalink)
Smile Re: will 1GB RAM works fine with 512MB?
as i'm using DDR 512MB and its DRAM freq. is 166.2MHz (Max Bandwidth 200MHz), Hynix if i buy DDR 1GB, does it comes in different frequencies...
even if i buy it of same make (same manufacturer) i.e.Hynix.
Old 02-06-2008, 01:35 PM   #7 (permalink)
The High 5 Flyer
sam9s's Avatar
If its 166Mhz then its called DDR-333 and the module name is called PC-2700. When you buy hynex 1 GB make sure that it is also DDR 333 or confirm the module name......... thats it.
sam9s is offline
Old 02-06-2008, 01:58 PM   #8 (permalink)
The real Bond
yogeshm.007's Avatar
Lightbulb Re: will 1GB RAM works fine with 512MB?
...you'll have to try very hard to get DDR 333 on suitable price point... What does your usage consist of? Having a look at your PC configuration, i'll suggest to part ways with current module and get a new DDR 400 1GB module or may be 2x512 DDR 400 modules (dual channel conf.)
yogeshm.007 is offline
Old 02-06-2008, 11:32 PM   #9 (permalink)
hello friend,
Thanks for ur keen interest in my problem...
MY PC Configuration is given below:-
Hardware:
CPU Type Intel Pentium 4 CPU 3.06GHz
Motherboard Intel D865GSA (3 PCI, 1 AGP, 2 DDR DIMM, Audio, Video, LAN)
->Chipset Intel Springdale-G i865G
->Video Adapter Intel(R) 82865G Graphics Controller (96 MB)
->3D Accelerator Intel Extreme Graphics 2
Disk Drive Seagate ST380211AS (80 GB, 7200 RPM, SATA-II)
Hard Disk Name Barracuda
Optical Drive SONY DVD RW DW-Q120A (DVD+RW)
Memory 512 MB RAM Hynix 333MHz
Monitor LG StudioWorks / HiSync 700B [17" CRT]
Software:
Operating System Microsoft Windows XP Professional SP 2
BIOS Version SA86510A.86A.1024.2006.0504.1017
Chipset:
Supported Memory Types DDR-266 SDRAM, DDR-333 SDRAM, DDR-400 SDRAM
Maximum Memory Amount 4 GB
even-though i've tried to give most complete discription, if something is still missing, ask me about that.
Hello Sam,
system is showing the following details
Real Clock 167 MHz (DDR)
Effective Clock 333 MHz
BUT the module.....
DIMM1: 512 MB PC3200 DDR SDRAM
which is the right one i should look out for buying......
Old 03-06-2008, 10:41 AM   #10 (permalink)
The High 5 Flyer
sam9s's Avatar
Hello Sam,
BUT the module.....
Nope somethings wrong PC3200 is DDR 400 and not DDR333. Which application are you using to get the information.......If there is any confusion go with the standard name which is DDR 333. Ask for DDR 333.
sam9s is offline
Old 03-06-2008, 08:19 PM   #11 (permalink)
hi sam,
i've used cpuid's cpu-z and everest... both the software gave the same info....
is the info. provided isn't right..
Old 03-06-2008, 11:46 PM   #12 (permalink)
The real Bond
Run cpuz.exe
Pressing F5 saves bmp image of current tab in the current directory (i.e. the directory where cpuz.exe is), hence save CPU, Memory and SPD tabs and show here. May be you board is running on lower FSB.
Also check number of ram slots from the combo box in the SPD tab.
Old 05-06-2008, 12:59 AM   #13 (permalink)
Run cpuz.exe
NO OF SLOTS = 2
i don't know how to insert image in forum from my computer. not as attachment but directly onto the reply page????!?!
Old 05-06-2008, 01:03 AM   #14 (permalink)
jal_desai's Avatar
ya if u have same frequency and slots available of course.. i purchased a Transcend 1 Gig RAM and added it to my already 256 MB RAM in my compaq lappie... make sure they are of same frequency and of same DDR version ofcourse..
TechExplorer.in
jal_desai is offline
Old 05-06-2008, 11:11 AM   #15 (permalink)
The real Bond
NO OF SLOTS = 2
Attachment would have done it also. Anyway, now to the point
I would recommend that you dispose off current ram module (try to make it into an exchange offer or so) and go for single module of 1GB DDR400 [Dual channel conf. seems not supported on your board, so dropped that idea]. Based on:
  • The current module you have operates at 333 and if you even purchase DDR 400 module, it will operate at 333 only.
  • Performance difference will be considerable switching to DDR 400.
  • You have not given any idea of your usage but 1GB is enough for XP if you are not into hardcore gaming (which you are not, based on you dont have AGP card installed) or graphics/video/audio editing or such. Hence, 1GB DDR400 will possibly perform better than 1.5 GB DDR333.
  • There wont be any difference between the price of DDR 400 and DDR 333 (actually just speculation, but no reason for being it incorrect)
BTW I have the above text in unordered list in the editor, but when posted no list is shown, just plain text. Have someone any idea?
Old 06-06-2008, 12:13 AM   #16 (permalink)
thanks yogesh, for your support. but take a look at the screenshot of cpu-z.
to be specific about the applications i use frequently are AutoCad 2004 and sometimes Xilinx
The games i play are Maxpayne 2, NFS underground....
i have no graphics card installed yet.....!!
i would prefer to keep my old 512MB RAM...(afterall this is the only thing this mess is all about )!
and the exchange isn't i think a good idea...
as you have said 1GB 400 will perform better than 1.5GB 333!!! what is the reason behind this......!!!
[IMG][/IMG]
Old 06-06-2008, 11:03 AM   #17 (permalink)
The real Bond
I meant that for present situation only. Because I was not sure of your usage and based on my experience 1GB ram is enough for most of the tasks of the PC (except the ones I mentioned in earlier post). So, difference between 1 GB and 1.5 GB would not have been noticeable but at the same time increase in frequency would surely result in more performance.
Hope you got it; the logic seems tricky, but i think it works
Looking at the screenshots, you current ram module indeed seems to be DDR400 [so anyway you should now keep it], but still, it is running at 333; there seems to be something wrong with the configuration.
You also missed the screenshot from the CPU section, that might have solved the puzzle.
Old 06-06-2008, 09:47 PM   #18 (permalink)
i'm sorry, i have mistakenly put the motherboard screen shot twice. here for the cpu. i hope it wolud help u to help me out !
Thanks a lot buddy, for your support!!!!
here i'm also giving the screenshots and some information from the everest hope it will help you to solve my problem..?
And some additional information here under:-
CPU
CPU Properties:
CPU Type Intel Pentium 4 524, 3066 MHz (23 x 133)
CPU Alias Prescott
CPU Stepping G1
Instruction Set x86, x86-64, MMX, SSE, SSE2, SSE3
Original Clock 3066 MHz
Min / Max CPU Multiplier 14x / 23x
Engineering Sample No
L1 Trace Cache 12K Instructions
L1 Data Cache 16 KB
L2 Cache 1 MB (On-Die, ECC, ATC, Full-Speed)
Multi CPU:
Motherboard ID Springdale-G
CPU #1 Intel(R) Pentium(R) 4 CPU 3.06GHz, 3058 MHz
CPU #2 Intel(R) Pentium(R) 4 CPU 3.06GHz, 3058 MHz
CPU Manufacturer:
Company Name Intel Corporation
Product Information http://www.intel.com/products/processor
CPU Utilization:
CPU #1 / HTT Unit #1 0 %
CPU #1 / HTT Unit #2 0 %
CPUID
CPUID Properties:
CPUID Manufacturer GenuineIntel
CPUID CPU Name Intel(R) Pentium(R) 4 CPU 3.06GHz
CPUID Revision 00000F49h
IA Brand ID 00h (Unknown)
Platform ID 29h / MC 10h (LGA775)
IA CPU Serial Number Unknown
Microcode Update Revision 3
HTT / CMP Units 2 / 1
Instruction Set:
64-bit x86 Extension (AMD64, Intel64) Supported
AMD 3DNow! Not Supported
AMD 3DNow! Professional Not Supported
AMD 3DNowPrefetch Not Supported
AMD Enhanced 3DNow! Not Supported
AMD Extended MMX Not Supported
AMD MisAligned SSE Not Supported
AMD SSE4A Not Supported
AMD SSE5 Not Supported
Cyrix Extended MMX Not Supported
IA-64 Not Supported
IA MMX Supported
IA SSE Supported
IA SSE 2 Supported
IA SSE 3 Supported
IA Supplemental SSE 3 Not Supported
IA SSE 4.1 Not Supported
IA SSE 4.2 Not Supported
VIA Alternate Instruction Set Not Supported
CLFLUSH Instruction Supported
CMPXCHG8B Instruction Supported
CMPXCHG16B Instruction Supported
Conditional Move Instruction Supported
LZCNT Instruction Not Supported
MONITOR / MWAIT Instruction Supported
POPCNT Instruction Not Supported
RDTSCP Instruction Not Supported
SYSCALL / SYSRET Instruction Not Supported
SYSENTER / SYSEXIT Instruction Supported
VIA FEMMS Instruction Not Supported
Security Features:
Advanced Cryptography Engine (ACE) Not Supported
Advanced Cryptography Engine 2 (ACE2) Not Supported
Data Execution Prevention (DEP, NX, EDB) Supported
Hardware Random Number Generator (RNG) Not Supported
PadLock Hash Engine (PHE) Not Supported
PadLock Montgomery Multiplier (PMM) Not Supported
Processor Serial Number (PSN) Not Supported
Power Management Features:
Automatic Clock Control Supported
Digital Thermometer Not Supported
Dynamic FSB Frequency Switching Not Supported
Enhanced Halt State (C1E) Not Supported
Enhanced SpeedStep Technology (EIST, ESS) Not Supported
Frequency ID Control Not Supported
Hardware P-State Control Not Supported
LongRun Not Supported
LongRun Table Interface Not Supported
PowerSaver 1.0 Not Supported
PowerSaver 2.0 Not Supported
PowerSaver 3.0 Not Supported
Processor Duty Cycle Control Supported
Software Thermal Control Not Supported
Temperature Sensing Diode Not Supported
Thermal Monitor 1 Supported
Thermal Monitor 2 Supported
Thermal Monitoring Not Supported
Thermal Trip Not Supported
Voltage ID Control Not Supported
CPUID Features:
1 GB Page Size Not Supported
36-bit Page Size Extension Supported
Address Region Registers (ARR) Not Supported
CPL Qualified Debug Store Supported
Debug Trace Store Supported
Debugging Extension Supported
Direct Cache Access Not Supported
Dynamic Acceleration Technology (IDA) Not Supported
Fast Save & Restore Supported
Hyper-Threading Technology (HTT) Supported, Enabled
Invariant Time Stamp Counter Supported
L1 Context ID Supported
Local APIC On Chip Supported
Machine Check Architecture (MCA) Supported
Machine Check Exception (MCE) Supported
Memory Configuration Registers (MCR) Not Supported
Memory Type Range Registers (MTRR) Supported
Model Specific Registers (MSR) Supported
Nested Paging Not Supported
Page Attribute Table (PAT) Supported
Page Global Extension Supported
Page Size Extension (PSE) Supported
Pending Break Event Supported
Physical Address Extension (PAE) Supported
Safer Mode Extensions (SMX) Not Supported
Secure Virtual Machine Extensions (Pacifica) Not Supported
Self-Snoop Supported
Time Stamp Counter (TSC) Supported
Virtual Machine Extensions (Vanderpool) Not Supported
Virtual Mode Extension Supported
CPUID Registers (CPU #1):
CPUID 00000000 00000005-756E6547-6C65746E-49656E69
CPUID 00000001 00000F49-00020800-0000651D-BFEBFBFF
CPUID 00000002 605B5001-00000000-00000000-007C7040
CPUID 00000003 00000000-00000000-00000000-00000000
CPUID 00000004 00004121-01C0003F-0000001F-00000000
CPUID 00000004 00004143-01C0103F-000003FF-00000000
CPUID 00000005 00000040-00000040-00000000-00000000
CPUID 80000000 80000008-00000000-00000000-00000000
CPUID 80000001 00000000-00000000-00000001-20100000
CPUID 80000002 20202020-20202020-20202020-6E492020
CPUID 80000003 286C6574-50202952-69746E65-52286D75
CPUID 80000004 20342029-20555043-36302E33-007A4847
CPUID 80000005 00000000-00000000-00000000-00000000
CPUID 80000006 00000000-00000000-04006040-00000000
CPUID 80000007 00000000-00000000-00000000-00000000
CPUID 80000008 00003024-00000000-00000000-00000000
CPUID Registers (CPU #2 Virtual):
CPUID 00000001 00000F49-01020800-0000651D-BFEBFBFF
MSR Registers:
MSR 00000017 0012-0000-0000-0000
MSR 0000002A 0000-0000-0000-0000
MSR 0000002C 0000-0000-1711-0917
MSR 0000008B 0000-0003-0000-0000
MSR 0000019A 0000-0000-0000-0002
MSR 0000019B 0000-0000-0000-0000
MSR 0000019C 0000-0000-0000-0000
MSR 0000019D 0000-0000-0000-0E2D
MSR 000001A0 0000-0000-2084-2081
MSR 000001A1 0000-0000-0000-0000
Motherboard
Motherboard Properties:
Motherboard ID 63-0100-000001-00101111-050406-iSPGDL_G$SA865024_BIOS DATE: 05/04/06 10:17:44 VER: 08.00.10
Motherboard Name Intel Sandy Canal D865GSA
Front Side Bus Properties:
Bus Type Intel GTL+
Bus Width 64-bit
Real Clock 133 MHz (QDR)
Effective Clock 533 MHz
Bandwidth 4266 MB/s
Memory Bus Properties:
Bus Type DDR SDRAM
Bus Width 64-bit
DRAM:FSB Ratio 5:4
Bandwidth 2667 MB/s
Chipset Bus Properties:
Bus Type Intel Hub Interface
Bus Width 8-bit
Real Clock 67 MHz (QDR)
Effective Clock 267 MHz
Bandwidth 267 MB/s
Motherboard Physical Info:
CPU Sockets/Slots 1 LGA775
Expansion Slots 3 PCI, 1 AGP
RAM Slots 2 DDR DIMM
Integrated Devices Audio, Video, LAN
Form Factor Micro ATX
Motherboard Size 220 mm x 240 mm
Motherboard Chipset i865G
Motherboard Manufacturer:
Product Information http://www.intel.com/products/motherboard/index.htm
BIOS Download http://downloadcenter.intel.com/default.aspx
Memory
Physical Memory:
Total 494 MB
Used 296 MB
Free 198 MB
Utilization 60 %
Swap Space:
Total 1156 MB
Used 216 MB
Free 939 MB
Utilization 19 %
Virtual Memory:
Total 1650 MB
Used 513 MB
Free 1137 MB
Utilization 31 %
Paging File:
Paging File C:\pagefile.sys
Initial / Maximum Size 744 MB / 1488 MB
Current Size 744 MB
Current / Peak Usage 10 MB / 10 MB
Utilization 1 %
Physical Address Extension (PAE):
Supported by Operating System Yes
Supported by CPU Yes
Active Yes
SPD
[ DIMM1: 512 MB PC3200 DDR SDRAM ]
Memory Module Properties:
Serial Number None
Module Size 512 MB (2 ranks, 4 banks)
Module Type Unbuffered
Memory Type DDR SDRAM
Memory Speed PC3200 (200 MHz)
Module Width 64 bit
Module Voltage SSTL 2.5
Error Detection Method None
Refresh Rate Reduced (7.8 us), Self-Refresh
Memory Timings:
@ 200 MHz 3.0-3-3-8 (CL-RCD-RP-RAS) / 11-14-2 (RC-RFC-RRD)
@ 166 MHz 2.5-3-3-7 (CL-RCD-RP-RAS) / 10-12-2 (RC-RFC-RRD)
@ 133 MHz 2.0-2-2-6 (CL-RCD-RP-RAS) / 8-10-2 (RC-RFC-RRD)
Memory Module Features:
Early RAS# Precharge Not Supported
Auto-Precharge Not Supported
Precharge All Not Supported
Write1/Read Burst Not Supported
Buffered Address/Control Inputs Not Supported
Registered Address/Control Inputs Not Supported
On-Card PLL (Clock) Not Supported
Buffered DQMB Inputs Not Supported
Registered DQMB Inputs Not Supported
Differential Clock Input Supported
Redundant Row Address Not Supported
Chipset
[ North Bridge: Intel Springdale-G i865G ]
North Bridge Properties:
North Bridge Intel Springdale-G i865G
Supported FSB Speeds FSB400, FSB533, FSB800
Revision / Stepping 02 / A2
Package Type 932 Pin FC-BGA
Package Size 3.75 cm x 3.75 cm
Core Voltage 1.5 V
In-Order Queue Depth 12
Memory Controller:
Type Dual Channel (128-bit)
Active Mode Single Channel (64-bit)
PAT Enabled
Memory Timings:
CAS Latency (CL) 2.5T
RAS To CAS Delay (tRCD) 3T
RAS Precharge (tRP) 3T
RAS Active Time (tRAS) 7T
Refresh Period (tREF) 7.8 us
Error Correction:
ECC Not Supported
ChipKill ECC Not Supported
RAID Not Supported
ECC Scrubbing Not Supported
Memory Slots:
DRAM Slot #1 512 MB (PC3200 DDR SDRAM)
Integrated Graphics Controller:
Graphics Controller Type Intel Extreme Graphics 2
Graphics Controller Status Enabled
Graphics Frame Buffer Size 16 MB
Chipset Manufacturer:
Product Information http://www.intel.com/products/chipsets
Driver Download http://support.intel.com/support/chipsets
Driver Update http://driveragent.com?ref=59
[ South Bridge: Intel 82801EB ICH5 ]
South Bridge Properties:
South Bridge Intel 82801EB ICH5
Revision / Stepping C2 / A2/A3
Package Type 460 Pin mBGA
Package Size 3.1 cm x 3.1 cm
Core Voltage 1.5 V
Debug - PCI
B00 D00 F00: Intel 82865G Memory Controller Hub [A-2]
Offset 00: 86 80 70 25 06 01 90 20 02 00 00 06 00 00 00 00
Offset 10: 08 00 00 F8 00 00 00 00 00 00 00 00 00 00 00 00
Offset 20: 00 00 00 00 00 00 00 00 00 00 00 00 86 80 70 25
Offset 30: 00 00 00 00 E4 00 00 00 00 00 00 00 00 00 00 00
Offset 40: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 50: 00 00 40 00 40 80 1C 00 00 00 00 00 00 00 00 00
Offset 60: 08 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 70: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 90: 10 11 01 00 00 33 33 00 00 00 00 00 00 1A 38 00
Offset A0: 02 00 30 00 17 42 00 1F 00 00 00 00 00 00 00 00
Offset B0: 00 00 00 00 30 00 00 00 00 00 00 00 10 10 00 00
Offset C0: 00 00 00 00 00 1F 0D 24 00 01 00 00 00 00 00 00
Offset D0: 02 28 04 0E 0B 0D 00 00 00 00 00 00 00 00 40 41
Offset E0: 00 00 00 00 09 00 06 01 00 02 00 00 00 00 00 00
Offset F0: 00 00 00 00 02 00 00 00 68 0F 03 00 00 00 00 00
B00 D02 F00: Intel 82865G Graphics Controller [A-2]
Offset 00: 86 80 72 25 07 00 90 00 02 00 00 03 00 00 00 00
Offset 10: 08 00 00 F0 00 00 A8 FF 01 EC 00 00 00 00 00 00
Offset 20: 00 00 00 00 00 00 00 00 00 00 00 00 86 80 4A 0C
Offset 30: 00 00 00 00 D0 00 00 00 00 00 00 00 10 01 00 00
Offset 40: 00 00 00 00 E0 23 E0 11 00 00 00 00 00 00 00 00
Offset 50: 00 00 40 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 60: 08 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 70: 01 00 00 00 00 00 01 02 FF 00 00 00 71 62 10 20
Offset 90: 03 00 00 00 00 80 A3 EE 00 00 00 00 00 00 00 00
Offset A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset B0: 30 08 04 00 08 04 41 00 00 00 00 00 00 00 00 00
Offset C0: 00 00 00 00 00 1F 0D 24 00 00 00 00 00 00 00 00
Offset D0: 01 00 21 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset E0: 28 04 00 00 09 00 06 01 00 00 00 00 00 00 00 00
Offset F0: 00 00 00 00 00 00 00 00 68 0F 03 00 00 00 00 00
B00 D06 F00: Intel 82865G I/O Memory Interface [A-2]
Offset 00: 86 80 76 25 02 00 80 00 02 00 80 08 00 00 00 00
Offset 10: 00 00 CF FE 00 00 00 00 00 00 00 00 00 00 00 00
Offset 20: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 30: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 40: 40 65 00 04 00 00 00 00 04 00 00 00 00 00 00 00
Offset 50: 01 00 8F 00 02 01 8F 00 00 00 00 00 00 00 00 00
Offset 60: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 70: 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 90: 00 00 55 05 00 00 00 00 00 00 00 00 00 00 00 00
Offset A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 20 08 00
Offset B0: 00 00 00 00 F0 43 FC 7D 01 00 00 00 09 00 00 00
Offset C0: 00 00 00 00 20 00 00 00 00 00 00 00 00 00 00 00
Offset D0: 00 00 00 00 00 00 00 00 FF FF FF FF FF FF FF 3F
Offset E0: 01 00 00 00 00 00 01 02 FF 0E 00 00 00 00 04 00
Offset F0: 00 0C 02 00 00 00 00 00 68 0F 03 00 74 F8 00 00
B00 D1D F00: Intel 82801EB ICH5 - USB Controller [A-2/A-3]
Offset 00: 86 80 D2 24 05 00 80 02 02 00 03 0C 00 00 80 00
Offset 10: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 20: 01 C8 00 00 00 00 00 00 00 00 00 00 86 80 4A 0C
Offset 30: 00 00 00 00 00 00 00 00 00 00 00 00 10 01 00 00
Offset 50: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 60: 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 90: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset C0: 00 2F 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset F0: 00 00 00 00 00 00 00 00 66 0F 05 00 00 00 00 00
B00 D1D F01: Intel 82801EB ICH5 - USB Controller [A-2/A-3]
Offset 00: 86 80 D4 24 05 00 80 02 02 00 03 0C 00 00 00 00
Offset 20: 01 CC 00 00 00 00 00 00 00 00 00 00 86 80 4A 0C
Offset 30: 00 00 00 00 00 00 00 00 00 00 00 00 13 02 00 00
B00 D1D F02: Intel 82801EB ICH5 - USB Controller [A-2/A-3]
Offset 00: 86 80 D7 24 05 00 80 02 02 00 03 0C 00 00 00 00
Offset 20: 01 D0 00 00 00 00 00 00 00 00 00 00 86 80 4A 0C
Offset 30: 00 00 00 00 00 00 00 00 00 00 00 00 12 03 00 00
B00 D1D F03: Intel 82801EB ICH5 - USB Controller [A-2/A-3]
Offset 00: 86 80 DE 24 05 00 80 02 02 00 03 0C 00 00 00 00
Offset 20: 01 D4 00 00 00 00 00 00 00 00 00 00 86 80 4A 0C
B00 D1D F07: Intel 82801EB ICH5 - Enhanced USB2 Controller [A-2/A-3]
Offset 00: 86 80 DD 24 06 01 90 02 02 20 03 0C 00 00 00 00
Offset 10: 00 FC A7 FF 00 00 00 00 00 00 00 00 00 00 00 00
Offset 30: 00 00 00 00 50 00 00 00 00 00 00 00 17 04 00 00
Offset 50: 01 58 C2 C9 00 00 00 00 0A 00 A0 20 00 00 00 00
Offset 60: 20 20 00 00 00 00 00 00 01 00 00 00 00 00 00 C0
Offset 70: 00 00 C7 3F 00 00 00 00 00 00 00 00 00 00 00 00
Offset 80: 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00
Offset C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset D0: 00 00 00 00 00 00 00 00 FF FF 00 00 10 00 00 00
Offset F0: 00 80 00 00 88 83 40 00 66 0F 05 00 06 14 00 00
B00 D1E F00: Intel 82801EB I/O Controller Hub 5 (ICH5) [A-2/A-3]
Offset 00: 86 80 4E 24 07 01 80 00 C2 00 04 06 00 00 01 00
Offset 10: 00 00 00 00 00 00 00 00 00 01 01 20 B0 B0 80 22
Offset 20: 80 FF 80 FF F0 FF 00 00 00 00 00 00 00 00 00 00
Offset 30: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 02
Offset 40: 02 28 30 76 00 00 00 00 00 00 00 00 00 00 00 00
Offset 50: 02 64 73 00 00 00 00 00 50 01 34 00 00 00 00 00
Offset 70: 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 80: 00 00 88 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset B0: 01 00 02 00 00 00 C0 00 00 00 00 00 00 00 00 00
Offset F0: 00 00 00 00 00 00 00 00 66 0F 05 00 00 00 47 3D
B00 D1F F00: Intel 82801EB ICH5 - LPC Bridge [A-2/A-3]
Offset 00: 86 80 D0 24 0F 01 80 02 02 00 01 06 00 00 80 00
Offset 40: 01 04 00 00 10 00 00 00 00 00 00 00 00 00 02 00
Offset 50: 00 00 00 00 00 00 00 00 01 05 00 00 10 00 00 00
Offset 60: 8B 83 8A 85 D0 00 00 00 80 80 80 89 00 00 00 00
Offset 90: FF FC 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset A0: 20 02 00 00 31 00 00 00 0D 00 00 00 00 03 01 00
Offset B0: 00 00 00 00 00 00 00 00 00 00 00 08 00 00 00 00
Offset D0: 86 21 00 00 00 0F 00 00 04 00 00 00 00 00 00 00
Offset E0: 10 00 00 80 81 06 0F 14 33 22 11 00 00 00 67 45
Offset F0: 00 00 40 00 04 00 00 00 66 0F 05 3E 00 00 00 02
B00 D1F F01: Intel 82801EB ICH5 - ATA-100 IDE Controller [A-2/A-3]
Offset 00: 86 80 DB 24 07 00 88 02 02 8A 01 01 00 00 00 00
Offset 10: 01 00 00 00 01 00 00 00 01 00 00 00 01 00 00 00
Offset 20: A1 FF 00 00 00 FC EF FF 00 00 00 00 86 80 4A 0C
Offset 30: 00 00 00 00 00 00 00 00 00 00 00 00 FF 01 00 00
Offset 40: 30 E3 00 80 0B 00 00 00 02 00 20 00 00 00 00 00
Offset 50: 00 00 00 00 22 00 00 00 00 00 00 00 00 00 00 00
Offset 60: 08 00 00 00 00 00 00 00 08 00 00 00 00 00 00 00
B00 D1F F02: Intel 82801EB ICH5 - Serial-ATA/150 IDE Controller [A-2/A-3]
Offset 00: 86 80 D1 24 05 00 A0 02 02 8F 01 01 00 00 00 00
Offset 10: 01 E8 00 00 01 E4 00 00 01 E0 00 00 01 DC 00 00
Offset 20: 01 D8 00 00 00 00 00 00 00 00 00 00 86 80 4A 0C
Offset 30: 00 00 00 00 00 00 00 00 00 00 00 00 12 01 00 00
Offset 40: 07 A3 00 80 00 00 00 00 01 00 01 00 00 00 00 00
Offset 50: 00 00 00 00 11 10 00 00 00 00 00 00 00 00 00 00
Offset 70: 01 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 80: 05 70 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 90: 00 00 13 00 00 20 00 00 00 00 00 00 00 00 00 00
B00 D1F F03: Intel 82801EB ICH5 - SMBus Controller [A-2/A-3]
Offset 00: 86 80 D3 24 01 00 80 02 02 00 05 0C 00 00 00 00
Offset 20: 01 C4 00 00 00 00 00 00 00 00 00 00 86 80 4A 0C
Offset 30: 00 00 00 00 00 00 00 00 00 00 00 00 03 02 00 00
Offset 40: 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B00 D1F F05: Intel 82801EB ICH5 - AC'97 Audio Controller [A-2/A-3]
Offset 00: 86 80 D5 24 06 00 90 02 02 00 01 04 00 00 00 00
Offset 10: 00 00 00 00 00 00 00 00 00 F8 A7 FF 00 F4 A7 FF
Offset 30: 00 00 00 00 50 00 00 00 00 00 00 00 11 02 00 00
Offset 40: 09 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 50: 01 00 C2 C9 00 00 00 00 00 00 00 00 00 00 00 00
B01 D03 F00: Realtek RTL8139 PCI Fast Ethernet Adapter [A/B/C]
Offset 00: EC 10 39 81 05 01 90 02 10 00 00 02 00 20 00 00
Offset 10: 01 B8 00 00 00 FC 8F FF 00 00 00 00 00 00 00 00
Offset 30: 00 00 00 00 50 00 00 00 00 00 00 00 17 01 20 40
Offset 50: 01 00 C2 F7 00 00 00 00 00 00 00 00 00 00 00 00
Offset F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
PCI-8086-2570: Intel i848/865/875/E7210 MMR
Offset 00: 04 08 08 08 08 08 08 08 00 00 00 00 00 00 00 00
Offset 10: 11 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 60: 85 0D E4 56 C6 42 14 00 71 62 10 20 01 D0 00 00
Debug - Video BIOS
C000:0000 U.R...000000000000......@...00IBM VGA Compatible BIOS. .[.k.y...
C000:0040 PCIR..r%........`........g...............u........ .....0........
C000:0080 ....................................d......d...... d.....0d......
C000:00C0 d......d......d......d.....0d......d.....0d......d ......d......d
C000:0100 ......d.....0d......d......d.....0$......$......d. ......... ....
C000:0140 `".......N... ....@............ ...88.......... .1X. (.........V
C000:0180 . .1X. .P.......... .0X. @........d..@A.&0..6.......... A. 0.`.
C000:01C0 ........$.`A.(00`........0*..Q.*@0p.........4..Q.* @...........=.
C000:0200 .Q.0@@.........H?@0b.2@@..........O@0b.2@@........ ..Y@0b.2@@....
C000:0240 .....h[..r.<P...........t..r.<P..........0.7..2.m..4....8 ....:..
C000:0280 ..<.E..A.7..C.m..E....I....K....M.E..P 7..R m..T ...X ...Z ...\
C000:02C0 E..`....a....b ...c....d....e ...f....g....h ...................
C000:0300 .................................................. ..............
C000:0340 ............For Evaluation Use Only....(........c-'(.+..........
C000:0380 .......................................(........c-'(.+..........
C000:03C0 .......................................P........c_ OP.U..........
don't ask me of what this information is all about!!!?
Old 06-06-2008, 11:05 PM   #19 (permalink)
The real Bond
Ok mate, your processor has FSB speed of 533 only; thats why DDR 400 (which you have) run at frequency of 333.
So (finally), you can/should now keep current 512 MB DDR 400 module and get another 1 GB DDR 400 module (as required by you).
BTW if you are to install it on your own then make sure you blow out dirt from the slot (apart from taken other precautions mentioned in the manual).
Old 07-06-2008, 11:09 AM   #20 (permalink)
Cool Buddy's Avatar
DDR RAM in dual channel
You got that wrong. only DDR2 modules work in dual channel.
Nokia 5230 :(
Canon IXUS 115 HS :)
Cool Buddy is offline
Old 07-06-2008, 12:09 PM   #21 (permalink)
The real Bond
Sorry, but you need to check your source. My board (865GBF) surely supports dual channel configuration and it can only have DDR ram modules.
Edit: Please refer to http://en.wikipedia.org/wiki/Dual-channel_architecture
Old 07-06-2008, 07:17 PM   #22 (permalink)
Thanks, a lot buddy.......!!!!
i've one more question..... just for my knowledge......
what does it mean......???
how FSB related to RAM frequency.?
hope you'll explain this ?
Old 08-06-2008, 11:13 PM   #23 (permalink)
anyone knows the reason of the above said thing....????
reply
Old 08-06-2008, 11:26 PM   #24 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Good question. Here...
http://www.hardwaregeeks.com/board/s...ad.php?t=24251
http://www.google.com/search?client=...utf-8&oe=utf-8
dheeraj_kumar is offline
Old 08-06-2008, 11:53 PM   #25 (permalink)
Google Bot
Pathik's Avatar
Bus speed = FSB/4
Ram freq = Bus speed * 2
Cpu clock = Bus speed * multiplier
Go figure.
Pathik is offline
One Fine Day... ashfahan Software Q&A 2 11-05-2008 09:02 PM
works fine on IE,but doesnt on firefox why? soln pls... NagpurDaMunda Software Q&A 11 02-06-2007 11:35 PM
A help would be fine ::cyborg:: QnA (read only) 8 12-12-2005 05:32 PM
Can't connect to net from xp but win98 works fine! serendipiti Software Q&A 7 29-11-2005 05:30 PM
- by gforz
- by gohan89
