31-05-2008, 09:18 AM
Gracias Senor
Which browser???
Hi all, I knew there are loads of threads regarding which browser to use..But I have started this since my needs are more specific.. Here goes the story.
Long long back I was using Opera since it has the tab feature and also the feature to start the Opera from where it was left previously..But days went by and Opera started to act bizarre..Like, it started very slowly, frequent closure etc., I again searched threads here and switched over to FF.
FF was cool, but it eated my resource 110%..I am using 256 MB of RAM and FF eating my resource made my PC dead slow.. Also I use to open all the website I use in tabs and use it..One more problem was with Gmail. From Gmail and FF I get a error unresponsive script and kills my FF instantly and also I download loads and this error makes the download stop.
Again I searched here and switched over to Opera again. Again new problems.. Most of the secured website doesn't load, youtube or online videos doesn't work. Only thing is Opera is very resource friendly. But I can't compromise losing access to secured website and online videos.
Now I am again thinking of switching to FF. But in a dilemma.
Guys pls help me out.
Here are my needs.
1. UI shuld look gud.
2. Need to store usernames and passwords.
3. Resource friendly.
4. Need to access all website and online vids.
5. Stability.
Any ideas will be much appreciated.
T i A
iPT 2G(S) - 8GB - JBn
iPhone 3GS 16GB - JBn
MAC OSx86 on P4 2.4Ghz
HTC Touch - Elfin - P3452 - WM 6.5
- Dont Dre@m... Juz Chase it -
31-05-2008, 09:40 AM
Legen-wait for it-dary!
Re: Which browser???
Your comp is affected by some adware or virus. Because Opera does all what you said, and it doesnt cause problems to the millions who use it. So your problem now is not choosing a browser, its cleaning your comp.
31-05-2008, 10:28 AM
Gracias Senor
Good try.. I hv installed ESET SS and COMODO..Updated till date..ran scans..nothin found. Any other ideas???
31-05-2008, 11:27 AM
Bot
use firefox and firefox optimizer it reduce the memory hunger of it to 1mb !! ya believe me it uses 1mb only with optimizer installed
FoxD was here
31-05-2008, 11:46 AM
heard first time about such firefox optimiser, thanks.....
31-05-2008, 01:02 PM
Gracias Senor
thnx for the suggestion..will go wit the maximum votes. need more sugg to decide.
31-05-2008, 01:44 PM
My personal choice is to use Opera for general browsing and for the few cases where websites dont work properly, I use IE7 or Firefox (depending on if I am in Windows or Linux).... I am using both Opera 9.27 and 9.50 beta2, and in both cases, I have access to most secure sites as well as video sites like Youtube... Which version of Opera are you currently trying? For me, the main problem in Opera is Gmail site which does not load correctly... Other than that, only a few random sites dont work properly in Opera for which I switch to IE/FF
Arun
31-05-2008, 06:07 PM
Gracias Senor
^^ I am using the stable 9.27 version of Opera.
31-05-2008, 06:26 PM
For me, all sites load correctly. I use 9.27 stable. Even GMail and youtube and metacafe and several other video sites.
31-05-2008, 08:36 PM
हॉर्न ओके प्लीज़
Just got this piece of software called 'firefox optimizer'. Its a total crapware. It does not reduce firefox memory consumption. It just makes it report drastically lower values. You can confirm this is by observing the change in page file usage after exiting firefox. As soon as you exit, it drops by about 40-50 MB-which is same as that consumed by firefox.
गीक होना माँगता
31-05-2008, 08:42 PM
High without substance...
i downloaded it from here
but i think there is a problem in the setup file.
can you link that page?
thank you
in my case that thing(software) did not work at all.
but there were no negative comments from the site i downloaded it.
off topic: i thought you were a doc.
I am Acrophobic, Entomophobic, Melissophobic. :).
Reason: Automerged Doublepost
31-05-2008, 08:58 PM
हॉर्न ओके प्लीज़
Even I downloaded from Sofftonic, the same site as you.
Can't say why there were no negative comments, though its is surprizing.
offtopic: Yes, i am a (almost)doc...last year MBBS
गीक होना माँगता
31-05-2008, 09:12 PM
opera is gud, long back i used only IE now i use opera
31-05-2008, 09:15 PM
Davislav Ivanuiz!!!
I prefer FireFox with extensions such as AdBlock Plus, IE-Tab, WML Browser & Stylish. A lot can be customized in FF, including the amount of memory it will use. Check out this page for some tweaking tips:
http://www.tweakguides.com/Firefox_8.html
I was here when the forum's swear filter kept bleeping out the word 'FUNK'. :crazy::censored::eeksign:
www.abhi247.com | The Photohblog A Little Lunacy! [v3]
Flickr!
01-06-2008, 10:34 PM
हॉर्न ओके प्लीज़
I was a fan of Opera. Feature-wise, opera is a rich browser. It has many high-utility features that even FF does not have. But accept the fact that it cannot render things as accurately as firefox does. Be it CSS or javascript.
गीक होना माँगता
01-06-2008, 11:57 PM
Techtree Reviewer
Here are my needs.
5. Stability.
T i A
Have you tried Safari? Give it a try. You might just switch to it full time like me.
02-06-2008, 08:20 AM
Gracias Senor
Not a problem trying it..downloadin now..wil post my feedback.
02-06-2008, 09:08 AM
Think Zen.
Opera is arguably the most standard compliant browser out there.
Problem's not with Opera, its the sites that optimize stuff for IE.
Still , 9.5Beta2 renders most sites better than the stable counterpart.
Do what you will; but not because you must. -- Zen Quote
02-06-2008, 10:30 AM
#19 (permalink)
Gracias Senor
Downloaded Safari..got a setup file..installed it..but no Safari found..Got a app Apple software update, checked for updates, found Safari, installed it, opened it, took ages to open(already Opera opened, this might be the reason, closed it, worked).
Look and feel is good. Opened Gmail, the fonts and looks are great. Opened Sathyam cinemas, worked(doesn't work in Opera). Big relief.
Tried my bank website, Oops, the tabs are missing, tried again, same.(In opera the tabs are visible, but when clicked on tab, it shows please wait while page loads and takes ages and never loads).
My issue is stil not fixed by Safari, then why should I go for it.
Very sad krazzy.
02-06-2008, 12:57 PM
#20 (permalink)
Seriously man, you've got some problem in your comp. I can load sathyam cinemas perfectly on Opera.
02-06-2008, 01:42 PM
#21 (permalink)
The real Bond
Have you tried Firefox 3.0 rc1; well, i'm using that for the last one week... it is still stable... a bit faster... lighter...
Get it from http://www.mozilla.com/en-US/firefox/all-rc.html
RC2 might release by this weekend...
02-06-2008, 01:51 PM
#22 (permalink)
Ballack Junior
opera is acc. to me the best for you..the problems you mention here are perhaps because due to some security settings..and have you got the plugins for online videos installed..that might be the reason for them not playing..
02-06-2008, 02:05 PM
#23 (permalink)
One more vote for Safari—clean interface, neat features and super-fast speed.
Which bank is yours?
02-06-2008, 02:10 PM
#24 (permalink)
The Smaller Bang
Firefox 3 is what I am using and it rocks, ecept for its slightly high resource usage(I use beta5)
Dillo is another browser that looks cute, is only 335kb, but you miss out a lot on extra features. But its good for low end systems.
Currently, Opera is the best, because firefox 2.xxx is old, and 3 is too new.
If you are willing to install KDE(which can be done only in Windows and Linux, not macintosh) then try out Konqueror which can use all plugins out of your firefox install. Its the fastest browser I have ever seen, and its KHTML rocks.
Avant is one of the best browsers for M$ platform based on IE Engine. Its dead fast.
Apple iPad 2 16GB WiFi
02-06-2008, 02:15 PM
#25 (permalink)
The real Bond
I'll press hard to upgrade
Konqueror4 is good (especially the one in beta stage) but it is still in early stage and very unstable.
I'm using Konqueror 4.1 Beta1 on openSUSE 10.3. Though it crashes randomly, the improvements from KDE3 version are so much that I still try to use it anyways...
02-06-2008, 02:16 PM
#26 (permalink)
Make Way the LORD is Here
Even I'd say their is some problem with ur pc cuz Opera is workin just fine for me
02-06-2008, 04:12 PM
#27 (permalink)
Gracias Senor
Okay..thnx for the suggestions and advice till now..lets say my PC is infected.
what I should do??? How to knw whether the infection is true??? Hw to test it out???
02-06-2008, 04:18 PM
#28 (permalink)
u have to try a better antivirus with higher detection rate like Antivir..
03-06-2008, 07:09 AM
#29 (permalink)
Gracias Senor
I did a complete scan of my computer frm ESET SS..nothing found..any other suggestions???
03-06-2008, 05:15 PM
#30 (permalink)
The real Bond
Also try http://www.safer-networking.org/en/index.html
Also, 256 MB RAM is not enough if you want to load multiple pages simultaneously.
How is your PC doing in general? How does its performance compare to what it used to be? Windows XP is also known to slow down with time, so even a windows reinstall might help.
To get more precise help (regarding tweaks to get more juice, if possible), please post following
CPU:
Motherboard:
Partitions; their number and format:
Do you have AGP card installed:
Search this Thread |
