Old 31-05-2008, 02:19 AM   #1 (permalink)
Ashok Verma's Avatar
Default where the documents folder has gone!!!!
hi friends, could someone help me out!
my problem is that, i've used the following code to apply some registry tweaks on my system. in which i've applied the one to hide shared documents in my Computer.!!
now, i want to undo the changes but i don't know how!!
Windows Registry Editor Version 5.00
;Disable Autoupdates
[HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\WindowsUpdate\AU]
"NoAutoUpdate"=dword:00000001;Disable Autoupdates
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate\Auto Update]
"AUOptions"=dword:00000001
"AUState"=dword:00000007
;Disable Messenger Service (to stop spam. Does not affect MSN or Windows Messenger)
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Messenger]
"Start"=dword:00000004
;Disable Remote Registry Service
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\RemoteRegistry]
;Disable UPS
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\UPS]
;Disable Indexing Service
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\CiSvc]
;Disable Wireless Zero Configuration
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\WZCSVC]
;Disable Smart Card Helper
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SCardSrv]
;Disable Portable Media Serial Number
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\WmdmPmSN]
;Disable Remote Desktop Help Session Manager
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\RDSessMgr]
;Disable Imapi CD-Burning Service
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\ImapiService]
;Disable IPSEC Services
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\PolicyAgent]
;Remove Shared Documents from My Computer
;[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\DelegateFolders\{59031a47-3f72-44a7-89c5-5595fe6b30ee}]
;Disable webservice for searching file-extensions (see HKCU for the second part)
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\system]
"NoInternetOpenWith"=dword:00000001
;Disable the Desktop Cleanup Wizard
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Desktop\CleanupWiz]
"NoRun"=dword:00000001
;NoLowDiskSpaceChecks won't check if you are low on diskspace and pop up a balloon telling you.
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer]
"NoLowDiskSpaceChecks"=dword:00000001
;Disable Recent Documents Menu
"NoRecentDocsMenu"=hex:01,00,00,00
;Remove "Shortcut to" on shortcuts
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer]
"link"=hex:00,00,00,00
;Disable Notify on new apps
"Start_NotifyNewApps"=dword:00000000
"NoInternetOpenWith"=dword:00000000
;Hide Printer Icon & Faxes from Start Menu
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced]
"Start_ShowPrinters"=dword:00000000
;Hide My Pictures From Start Menu
"Start_ShowMyPics"=dword:00000000
;Hide My Music From Start Menu
"Start_ShowMyMusic"=dword:00000000
;Removing Shared Documents From My Computer
"NoSharedDocuments"=dword:00000000
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer]
as i've disabled the system restore i can't restore my previous settings...
i there any way to get it back.
i'm using windows XP SP2
Ashok Verma is offline
Old 31-05-2008, 04:41 AM   #2 (permalink)
Seed is the Life!!
shift's Avatar
Default Re: where the documents folder has gone!!!!
download Tweak UI Powertoys, there is an option for hiding/unhiding of documents in My Computer
Stupidity Causes Cancer !!
shift is offline
Old 31-05-2008, 09:35 AM   #3 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
[HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\Policies\Explorer]
"NoSharedDocuments"=dword:00000001
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\Curr entVersion\Policies\Explorer]
Copy paste the above into notepad, save it as a .reg file, and right click, merge. Restart if needed. If it doesnt work, try changing the 1s to 0s and try again.
dheeraj_kumar is offline
Old 31-05-2008, 10:02 AM   #4 (permalink)
yes buddy i've tried that one, but doen't works?? any ohter trick...!
from where i'll get that....
please tell!
Old 02-06-2008, 10:44 AM   #5 (permalink)
please help me out friends...
Old 02-06-2008, 11:24 AM   #6 (permalink)
Seed is the Life!!
shift's Avatar
http://www.microsoft.com/windowsxp/d...powertoys.mspx
shift is offline
Old 02-06-2008, 12:48 PM   #7 (permalink)
If nothing works, you can use system restore to restore your computer to a date when the problem wasn't there
ThinkFree is offline
Old 02-06-2008, 10:42 PM   #8 (permalink)
hello asnvin, thanks for your support but as i've already metion that i had disabled the system restore. i've no earlier restore point..!!
any other way...
as i got into the problem using registry. there must be some solution for this in it.??!!
what do you think...???!!
Old 03-06-2008, 12:32 PM   #9 (permalink)
^^The folder hasn't gone anywhere. It has just hidden. So you can still access it from the desktop shortcut. If you are not having it , go to Desktop properties(right click), then to Desktop Tab>Customize desktop button and here click on checkbox next to My Documents. To make it visible in MyComputer, you have to tweak registry.
Old 03-06-2008, 01:17 PM   #10 (permalink)
Seed is the Life!!
shift's Avatar
here's the solution
install this --> http://rapidshare.com/files/119724517/TweakUi.zip.html
and open it
click My Computer on the side
click the radio button Files stored on This Computer
works 100%
shift is offline
Old 03-06-2008, 08:25 PM   #11 (permalink)
i think this key has does the above said problem. in addition of removing(Hiding) the sahred doc. folder it also removed(hidden) the user's folders. isn't it!
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\Curr entVersion\Explorer\MyComputer\NameSpace\DelegateF olders\{59031a47-3f72-44a7-89c5-5595fe6b30ee}]
Old 03-06-2008, 10:50 PM   #12 (permalink)
Seed is the Life!!
shift's Avatar
yes, both Shared and User's Document
shift is offline
Help: Change default my documents folder speedyguy Software Q&A 6 21-05-2008 09:49 PM
A file or a folder or My Documents????? technoraja Chit-Chat 1 22-07-2007 09:11 AM
change default documents folder in vista iMav Software Q&A 1 05-06-2007 12:29 AM
Reg: My Recent Documents Folder Missing sree_shan Software Q&A 4 22-10-2006 11:25 PM
Moving the Documents and Settings folder... thestrategist Software Q&A 7 28-05-2006 12:24 PM
- by gforz
- by gohan89
