Old 27-04-2005, 04:37 PM   #1 (permalink)
Default SECURITY TAB MISSING
HI,
i have NTFS partition (C: and D in my computer. i know that when we see properties of any folder, then 4 tabs appear namely: General, Sharing, Security and Sharing. i work then mostly on security tab for grant of folder permissions.
recently, on installing Win Xp Pro OS, am seeing that there is no security tab though i have NTFS partition. how can i make it appear again.
thanks
taken is offline
Old 27-04-2005, 05:29 PM   #2 (permalink)
Disable Simple file sharing from Folder options.You should now be able to see the tabs & change them accordingly.
Windows Explorer>Tools>Folder Options>View>At the very bottom of the list uncheck "Use Simple File sharing" box.
www.Oobertech.net
digen is offline
Old 28-04-2005, 05:42 PM   #3 (permalink)
thanks,
it helped and the problem is solved !!!!!!
taken is offline
Old 29-04-2005, 03:00 AM   #4 (permalink)
I'm glad it did.
www.Oobertech.net
digen is offline
- by gforz
- by gohan89
