Old 30-05-2008, 01:00 PM   #1 (permalink)
Red face Best trick to do partition of hard disk
Hi guys,
well just bought a 250 GB of western hard disk drive n will install a fresh XP professional OS on it .... now i want to partition it in the following manner....
C:\ 80GB
n other drives as 56GB each......
Now guys wats the best possible way to do it..... should i use disk partion magic
or is there some other way to do it...
Plz suggest.... (the procedure in detail.... as newbie to it)
thanking in advance
clifford goa
clifford is offline
Old 30-05-2008, 01:11 PM   #2 (permalink)
mayneu's Avatar
Default Re: Best trick to do partition of hard disk
Use Acronis Disk Director Suite... Best GUI and simple to use... Just google for it if u r looking for full working version...
mayneu is offline
Old 30-05-2008, 02:39 PM   #3 (permalink)
already on mate.... thanks for ur helps....
clifford is offline
Old 30-05-2008, 04:41 PM   #4 (permalink)
aminsagar123's Avatar
download hiren boot cd ISO and burn it to a cd. it got many useful tools for hdd partitioning.
aminsagar123 is offline
Old 31-05-2008, 01:34 AM   #5 (permalink)
AMD user for 9 yrs!!
rollcage's Avatar
use megaISO and choose Acronis Disk Partition manager. very good and fast,
for .. XP -> 30Gb is morethan sufficient.
I use 10Gb for XP. (slipstream xp use less space )
rollcage is offline
Old 31-05-2008, 02:16 PM   #6 (permalink)
pushkar's Avatar
Get Hiren's Boot CD, boot using it, and use Partition Magic or Acronis Disk Director Suite.
pushkar is offline
help me regarding hard disk partion pritzdj QnA (read only) 2 15-05-2008 01:28 PM
Hard Drive partion ???????? kiranbajpe Hardware Q&A 1 13-06-2007 11:06 PM
all files from IDE hard disk with windows 2000 to SATA II hard disk with windows jagadish2005 Software Q&A 8 10-04-2007 11:08 AM
compaq deskpro ep/sb series not detecting hard disk disk aditya169 QnA (read only) 3 22-05-2005 07:14 PM
80GB hard disk converted into 10780 MB hard disk ssingha QnA (read only) 12 24-08-2004 11:57 AM
- by gforz
- by gohan89
