Old 29-05-2008, 10:53 PM   #1 (permalink)
Default How to increase the bitrate of audio??
The queation is simple:
How do we increase the bitrate of a sound track(any format).Are there any softwares available for the purpose and are any freewares available too??
anshul is offline
Old 29-05-2008, 11:02 PM   #2 (permalink)
TooR
alok4best's Avatar
Default Re: How to increase the bitrate of audio??
yes, DBAmp music converter. and many more .
But it wont enhance the quality of the audio...only file size will increase..
I wish !!
alok4best is offline
Old 29-05-2008, 11:11 PM   #3 (permalink)
Then isn't there any way to increase the sound quality??
anshul is offline
Old 29-05-2008, 11:46 PM   #4 (permalink)
pushkar's Avatar
No, you can't upgrade a lower quality track to higher quality.
pushkar is offline
Old 30-05-2008, 08:54 AM   #5 (permalink)
ajayritik's Avatar
^^ +1. Even I had similar query couple of months back. There is no point using any software to increase the bit rate as it will not help you much in the quality enhancement.
ajayritik is offline
Old 30-05-2008, 09:08 AM   #6 (permalink)
Think Zen.
ray|raven's Avatar
It may as well decrease the quality, Transcoding is EBIL!!
Do what you will; but not because you must. -- Zen Quote
ray|raven is offline
Old 30-05-2008, 04:04 PM   #7 (permalink)
ajayritik's Avatar
What does EBIL stand for? I'm Sorry dude I'm new to these acronymns!
Old 30-05-2008, 04:17 PM   #8 (permalink)
Think Zen.
ray|raven's Avatar
Ebil is just another way of saying Evil.
http://www.urbandictionary.com/define.php?term=ebil
Old 31-05-2008, 01:43 AM   #9 (permalink)
AMD user for 9 yrs!!
rollcage's Avatar
you can always do that ... many are available .. I like dbpoweramp. ya its freeware .. one of the best open source stuff around.
but to your question .. why you want to increase it.
you can not increase the quality back.
see its like that .. when you accidentally cut a 100 rupee note you can not fix it back
.. its 100 rupees gone like a wind. same with bit rates. if you rip a song from a cd at 64kbps
.. you can do no good by converting that to 128kbps
.. the only way to increase the quality is to rip the song again from the original source.
I hope this helps in understanding the theory.
bye4now dude
rollcage is offline
Old 31-05-2008, 02:18 AM   #10 (permalink)
Check this out if this helps...
hxxp://www.ogg-converter.com/download.htm
agm_1052001 is offline
Old 31-05-2008, 02:14 PM   #11 (permalink)
pushkar's Avatar
dbPoweramp is open source?
pushkar is offline
Old 31-05-2008, 02:18 PM   #12 (permalink)
rollcage's Avatar
dont grab the words out of my mouth man.. ya its not open source, I meant the Freeware stuff.. its also technically open to everyone .. free to try free to use. I meant awesome Freeware.
rollcage is offline
Old 02-06-2008, 07:20 PM   #13 (permalink)
Try MP3Gain.. opensource http://mp3gain.sourceforge.net/
enjoy is offline
Old 02-06-2008, 07:28 PM   #14 (permalink)
Davislav Ivanuiz!!!
Kl@w-24's Avatar
MP3Gain is NOT for encoding/decoding. It's a software that can alter the volume of MP3 files according to ur taste!!
I was here when the forum's swear filter kept bleeping out the word 'FUNK'. :crazy::censored::eeksign:
www.abhi247.com | The Photohblog A Little Lunacy! [v3]
Flickr!
Kl@w-24 is online now
Old 02-06-2008, 11:56 PM   #15 (permalink)
Attitude matters
Ponmayilal's Avatar
May be a little out of context but the only occasion I found it necessary to resample my mp3s was when I wanted to convert them to Sony Atrac+ format to be played on Sony Discman.
The conversion software by Sony required that all Mp3s be in CBR 128. I had to convert all my VBRs to CBR 128 before converting them to Atrac+.And I think I used the Goldwave Digital Audio editor for the VBR to CBR conversion.
Goldwave can also be used to resample from a lower bit rate to higher bit rate but do this only in exceptional circumstances like this.Otherwise there is simply no point in doing that.
Ponmayilal is offline
mp3 bitrate converter beanstalk_230 Software Q&A 13 27-01-2008 08:42 PM
What's the bitrate on your phone? Hitboxx Mobiles and Tablets 13 16-10-2007 05:40 PM
how to increase audio volume hansraj QnA (read only) 1 18-10-2006 08:05 PM
How to view the video and audio bitrate of a .mpg file? rachitar Software Q&A 2 09-01-2006 10:48 AM
If Increase the RAM Then the System speed will increase muralikrishnan QnA (read only) 9 23-09-2005 03:52 PM
- by gforz
- by gohan89
