28-05-2008, 02:55 PM
shutdown using keyboard
Is there any method to set shutdown using keyboard.i mean key combinations when my monitor is off.
28-05-2008, 03:24 PM
Re: shutdown using keyboard
The routine I suppose -- Alt F4 followed by right arrow key and then Enter key.
28-05-2008, 03:40 PM
Davislav Ivanuiz!!!
Win+D -----------> Make sure desktop is selected
Alt+F4 -----------> Close explorer session
U -----------> Accelerator key for 'Turn off'
I was here when the forum's swear filter kept bleeping out the word 'FUNK'. :crazy::censored::eeksign:
www.abhi247.com | The Photohblog A Little Lunacy! [v3]
Flickr!
28-05-2008, 03:41 PM
Legen-wait for it-dary!
First you may want to do a windows key+m or windows key + d
But you can always use macro software, to set a key combination for shutting down the computer. for example, press control+shift+f12 or something like that to shut down. You can use AutoHotKey or AutoIt for free macro software. And please read the documentation for using them.
28-05-2008, 05:10 PM
Best way is .....
window
u
u
3 button press and done...
28-05-2008, 08:02 PM
Oh thats right  good work, praveen
29-05-2008, 12:00 PM
The Frozen Nova
The simplest way is using the power button on keyboard (if present)
www.nerdweed.blogspot.com
29-05-2008, 12:28 PM
OSS Enthusiast!
Can some one post the same for Linux(Ubuntu 8)?
Do you know, Shinigamis only eat apples???
29-05-2008, 06:21 PM
Thanks Everybody
29-05-2008, 06:37 PM
NP : Crysis
best method is just press the power button on the cabby...in case of ATX systems, proper shut down will get initiated
29-05-2008, 06:41 PM
^for ubuntu i think, ALT+f2 -> poweroff -> Enter will work.
for windows methods told by both abh1shek and xbonez will do.
Dell Inspiron 1525 - C2D 2 Ghz, 3GB, 250GB, X3100 :)
Samsung Omnia Pro B7610 with Stock WM 6.1 ROM
Blog: http://www.sumitbhardwaj.co.in/blog
29-05-2008, 07:34 PM
alt+F4+u=shut down
29-05-2008, 09:39 PM
^^ you might want to press windows+M or windows+D before that...
30-05-2008, 10:17 AM
disconnect the power cord.!!
30-05-2008, 11:21 AM
Old is Gold
Originally Posted by p4praveen
Best way is .....
window
u
u
This one is C   L...
30-05-2008, 12:01 PM
It would be better to switch off the power supply
31-05-2008, 02:02 AM
AMD user for 9 yrs!!
^ haha .. PJ .. not taken man.. thats absurd
and
folks what is the shortcut for the hibernate .. !!
i just use the one single push to power button and my system hibernates in secs .. quick. I dont shutdown, unless i install something new.
31-05-2008, 02:16 AM
win+u+u = shutdown (@parveen)
win+u+r = restart
wind+u+l = log off
31-05-2008, 04:40 AM
#19 (permalink)
and
WIN+U+H = HIBERNATE
31-05-2008, 01:12 PM
#20 (permalink)
Originally Posted by paid
WIN+U+H = HIBERNATE
not working
31-05-2008, 06:42 PM
#21 (permalink)
Win
U
hold shift
H
31-05-2008, 11:21 PM
#22 (permalink)
not working
Check if Hibernation enabled on your computer......... if not enable from Power Options then use these keys......... working fine at my place and even tried other computers
01-06-2008, 03:38 AM
#23 (permalink)
haha .. you are funny ... didnt ya read my post ... i use hibernate instead of shutdown.. so enable to hua na bhai and my point was that that shortcut is not working.
but still I think the best is to just press the power button. one push so simple.. it cant be better than that.
Search this Thread |
