Old 26-04-2005, 10:05 PM   #1 (permalink)
Default DVD DRIVE PROBLEM
The last two chapters of a dual layer movie DVD (DVD9) is not playing on my LITE-ON DVD ROM Model JLMS XJ-HD166S. Error No 89020003 is displayed on the screen, implying the disc is dirty and require cleaning. However, the same disc plays perfectly well in my office PC LITE-ON DVD ROM drive without being cleant and also my old stand alone PIONEER DVD player Model DV-525. I have opened the DVD drive and cleaned the lens manually, but the problem persists. What could be the problem with the drive ?
daumaster is offline
Old 27-04-2005, 04:07 PM   #2 (permalink)
vignesh's Avatar
Certain dvd`s have a country or area code set that to 0 in the dvdplayer you use and it should work
vignesh is offline
Old 27-04-2005, 05:51 PM   #3 (permalink)
The DVD is playing. Only last two chapters are not playing in my LITE-ON DVD Drive. But these two chapters are playing in my stand alone PIONEER DVD player Model DV-525
Old 27-04-2005, 08:53 PM   #4 (permalink)
It's not a problem at all. Some drives/players play scratched/dirty disks better than someother drives/players.
Try ripping the DVD to your hard disk using DVD Shrink (with "no compression"). Use the ISO option. Use Daemon Tools to create a virtual drive. Mount the ripped *.ISO using D Tools and watch the movie like any normal disc.
All software mentioned above is free and available at www.doom9.net
Keith Sebastian is offline
Old 07-05-2005, 04:51 PM   #5 (permalink)
I agree with Keith. Ur drive is OK, don't mess wid it.
PM me if you have any difficulties regarding your Symbian OS cellphone.
suhasingale is offline
Old 07-05-2005, 06:20 PM   #6 (permalink)
Default a different dvd problem
hi
i just upgraded my pioneer 8x dvd writer to samsung 16x dula layer dvd writer. and after this i burnt few dvd in DVD-R. it works in driver which are only DVD-ROM like samsung, lite-on, asus & doesn't work in combo drives. it doesn't work in my dvd player too & even in my sony vaio notebook which has a dual layer dvd writer. a strange problem. how can i make this dvd work on all drives. i did not hav this prob with pioneer.
mahesh.
realmmahesh is offline
Old 08-05-2005, 03:48 AM   #7 (permalink)
>The last two chapters of a dual layer movie DVD (DVD9) is not playing on my LITE-ON DVD ROM Model JLMS XJ-HD166S. Error No 89020003 is displayed on the screen, implying the disc is dirty and require cleaning. However, the same disc plays perfectly well in my office PC LITE-ON DVD ROM drive without being cleant and also my old stand alone PIONEER DVD player Model DV-525. I have opened the DVD drive and cleaned the lens manually, but the problem persists. What could be the problem with the drive ?<
I dont know if liteon DVD rom drives are similar to the DVD burners but I did find out that calibration data learnt by the drive can make a disk redable or not. IE just by using some disks, the drive does some dynamic learning stuff which can make some disks unredable. I never believed this before. I had saved out 2 sets of calibration data and I found a disk which had major reading problems so I flashed back to the older version and the disk started reading fine, flashed back to the new and reading problems. I dont know how to fix this.
AlienTech is offline
- by gforz
- by gohan89
