Old 26-05-2008, 04:47 PM   #1 (permalink)
Exclamation Help Files
Can I create .chm files (Compiled HTML Files) using notepad or ms-word without using any tool to create it? tell me the method....
pacificboy is offline
Old 26-05-2008, 08:59 PM   #2 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Default Re: Help Files
Since all pages are just HTML files, you can use notepad and MS Word to create the individual pages, and use HTML Help Workshop to compile them into a CHM, or you can use 3rd party softwares to do the same.
dheeraj_kumar is offline
convert .exe files to .c files Lucky Rathod Programming 17 30-04-2008 11:05 AM
Marking torrent files as junk or ability to report bad files phreak0ut QnA (read only) 6 08-04-2008 03:46 PM
do bin and iso files have larger files sizes than it's contents??? tango_cash Software Q&A 5 29-02-2008 08:29 PM
how to convert dvd files to rmvb files raj4frns QnA (read only) 1 21-12-2006 10:26 PM
converting.pdy files directly to .doc files. kumarn_2004 QnA (read only) 5 23-02-2005 10:47 PM
- by gforz
- by gohan89
