Old 26-04-2005, 06:11 PM   #1 (permalink)
Stabbing my shoe
Default Help me format my hard disk..
Hi! Guys..
Plz help me in installing my computer..
U see I have 3 partitions on my 40GB Seagate harddisk:
C: (containing all my important files -- abot 10 GB)
D: (Win XP SP2 original installed - about 10 GB)
SuSE 9.1 (LINUX installed on about 18 GB)
Now, I wish to save my data on C:. For this I will bring a second hard disk and copy the data.
After that, I wish to completely format my hard drive and remove all partitions. Then, I wish to create 3 paritions of 18 GB (for WIN XP SP2), 14 GB (Data), 5 GB (for LINUX).
I can install WIN XP and LINUX, but I don't know how to format my hard drive and create partitions.
Plz tell me the procedure and all the things I would be needing (like Boot Up Disk, etc.)
>> Siddhartha <<
> http://sidroy.wordpress.com <
> Beauty lies in the eyes of the Beer Holder <
//siddhartha// is offline
Old 26-04-2005, 06:19 PM   #2 (permalink)
why need title?
bharathbala2003's Avatar
simple.. get ya XP Cd first.. and start up the computer.. after changing the boot sequence to CD.. then it will ask u to install XP.. there u can have the option of formating.. there create partition and format em.. simple.. if u feel this is difficult.. get a 98 cd and run Fdisk and do the partition..
bharathbala2003 is offline
Old 26-04-2005, 06:21 PM   #3 (permalink)
Stabbing my shoe
How to use Fdisk and can this option be used with a Win 98 boot up disk?
And does Win XP have the option 2 format Hard disk.. I need 2 check again..
>> Siddhartha <<
Old 26-04-2005, 06:26 PM   #4 (permalink)
why need title?
well sorry i think i made a mistake.. yes u can format the disks.. but i dont think u can format the drive thats got XP.. first of all i suppose ur system as a NTFS partition.. so better get a XP cd.. and change the boot sequence to CDrom.. u can do that in BIOS
(in Standard CMOS SETUP) then restart the system.. when the XP setup starts.. select the option to del XP and then format the system.. then create partitions then format em.. thats it.. u can install XP again and then go on to install Linux..
Old 26-04-2005, 08:28 PM   #5 (permalink)
After copying ur data to the other disk .. just confirm tht ur boot sequence has CDROM as its 1st option in BIOS ...
then insert an XP cd boot ur system from tht CD & follow the procedure after . .pressing 'F8' .. setup will ask U to delete & recreate the partitions .. delete all the partitions by pressing 'D' . & recreate the partitions pressing 'C' .. Setup will itself ask U to set the sizes of various partitions ...
& yeah! Install windows first & then LINUX to avoid some hectic problem
Gud luck!
At times in ur life just to do things right U have to be steady & sacrifice sth which u want the most.....even ur dreamzz tooo....
yehmeriidhain is offline
Old 27-04-2005, 12:55 AM   #6 (permalink)
hey i hav win98SE.2 partions c and d.wen formating c drive,i do require a boot disk rt...wats the purpose of this...secondly,i dont hav win98 original cd,but hav saved all files in D drive(the whole setup files etc of win98SE)...So wen it will ask abt the cd,wat do i do..
do tell
tx
krisjr is offline
Old 27-04-2005, 06:10 AM   #7 (permalink)
winXP do have an option to format HDD,but not thru fdisk..its more user friendly...
nd for formatting thru fdisk here is the link...>>
http://www.perfectdrivers.com/howto/fdisk-format.html
grinning_devil is offline
Old 27-04-2005, 10:36 AM   #8 (permalink)
Stabbing my shoe
For @bharatbala2003, I have all FAT32 partitions.. No, NTFS ones.. I will try all your advices as soon as I get a hard disk from my frnds.. I had gone to my system dealer and he said he would charge me Rs. 250/- for installing WIN XP again after formatting my hard drives.. I hve got plenty of info now and will do the work myself..
>> Siddhartha <<
Old 27-04-2005, 02:27 PM   #9 (permalink)
WOW...!!! had i been charging this much...i wud be playing with $$$$$ !!!
Old 27-04-2005, 02:52 PM   #10 (permalink)
If you are in bangalore come to my place i will do it for free
**** happens
pradeep_chauhan is offline
Old 27-04-2005, 03:20 PM   #11 (permalink)
Stabbing my shoe
Oh! I wish I lived in Bangalore.. Anywys, thanx @pradeep_chauhan for your kind proposal. If I happen to come to BANGALORE, I will BANG into your house and fly with ur system..
>> Siddhartha <<
Old 27-04-2005, 09:18 PM   #12 (permalink)
vignesh's Avatar
do tell
tx
You can just boot into msdos mode from the shutdown menu and format the partition since you are using 98
vignesh is offline
- by gforz
- by gohan89
