I just bought a new machine with DP35DP mobo......and it does not have ps/2 pin for key board but i bought a ps/2 pinned kbd ..... then bought a extension for that converts ps/2 into USB...... now i have problem ... media buttons r not working.....
I have logitec keboard......
Have you installed the drivers? you'll get them via a CD, or you can get them in Logitech's website.
